El-cheapo coilovers
not really cheap when you add the postage costs. the guy has 452 100% feedbacks.
Tim
1995 S2 Avant, ruby red - ** SOLD TO ROSS **
Golf Rallye G60 ** SOLD **
Golf MK2 Oaky with R32 engine
Audi A6 Avant 1.9 TDi 130
Golf MK2 8v Race carComment
i have done this very cheap has the disired effect,
i paid £35 for platform/top/threaded tube
£25 2.25"id x 8" long springs
half a day with a welder and an angle grinder
Ok, pics please..Originally posted by WabTheKingi have done this very cheap has the disired effect,
What about spring rates and so on. Which kit did you use?Comment
400lbs x 8" long, will take pics later,
see my crude drawing of how i did it
took strut apart
cut platform off
got threaded sleeve slide on fit for strut OD
weld on round the bottom
2 C nuts one is the spring retainer the one below is the locking nut
re assemble shocker in strut
slide new spring over
put top mount on as usuall with new spring top retainerAttached Files
Originally posted by HenkaAutoCad??
"the-hot-place"??
This is from www.tas.uk.com and shows the threaded tube.
HTH
DavidAttached FilesComment
yeah steel threaded seamless tubeOriginally posted by HenkaAutoCad??
Ok, I get the pic. You welded it in place - does that mean they are steel collars? Won't that rust like "the-hot-place"??
probably will rust but how often are you planing on adusting them? you could get the paint blasted off the bottom of your strut and then get the whole thing electro plated
the aluminium C nuts are already anodised i think (well mine havent gone crappy yet) either that or they are high qualitly aluminium
i just sprayed my threads with waxoil
How did you cut the orginals? The rears are easy but the front has a "arm" and I was talking to one specialist here in Finland few years back, he wanted to use mill to cut it, makes even and straight cut, and the front strut is impossible to put in a mill.
To the orginal question, it sell SPRINGS to coilovers, not full systems.Comment
i didnt go anywhere near the arm, i hacked off the platform, then tidyed up where it was welded on (which is much higher than the arm) with a grinder/flexi disc
i wanted to put it in a lathe to turn it off - dont get the advange of milling it off
Looks pretty good to me!
The Perfectionist
too cheap to be true.....someone tryed this??
