4 Wheel Alignment specs
This is a sticky topic.
Gave these guys a call and found out that Awesome GTI in Manchester do full geometry setup and have all settings for all VAG cars (except newest RS6, R8 etc) stored in their machine.
£67.50+VAT
You get printouts etc.
Don't know what they are like though.
Forum visit to bring cost down????
Anyone interested?
Maybe combined with a RR session?UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Triumph Daytona 955i - mmmmmm :fire:
80 dag dag :driving:
What wheel alignment numbers/spec should i have with my H&R Spring lowered + yellow koni shocks.?? cause it has been a bit snaky on the road and my rear tyres have twice as mutch wear.
Audi S2 Coupe - 92
Koni + H&R. PowerFlex bushes. 3" Exhaust
RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
Best ET 2007 201m 8.15@140km/h
Best ET 2008 402m 12.34@177km/h
My Project
http://www.s2forum.com/forum/showthread.php?t=16997Comment
1976 RD250E / 350LC cafe racerComment
hey guys,
ive been having some problems with my 2.6coupe over the past few months, last time it snowed real bad i ended up getting overly friendly with a curb and bent my wishbone. I promptly replaced it with a pressed one with a new ball joint, whilst i was there i did the same to both sides and also replaced the track rod ends and adjusters both sides too. I set the tracking right after but had no camber gauge until now. am i right in thinking that the camber adjustment is all in that bottom ball joint or are the nuts on the carrier excentric like on coilovers n such? I restore air cooled vw's for a living so im used to shims and torsion bars haha. any help would be great,
cheers, TomComment
Camber is adjusted with the position of the lower balljoints, strut bolts are just straight bolts however you can slack them off and move the position of the strut if you run out of camber adjustment at the ball joint.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Anyone used these guys. been past them a few times in the avant and used them for my coupe setup (but I had a knackered wishbone which was the problem in the end) so I cant really comment. they did gove good service. What about price? On par?
Should I have this done after all the bones have had powerflex put in or just after new wheels have gone on
AzDark Grey Avant
RS2 FARB
Alloy Subframe BushesComment
anyone requiring geo setup in the manchester area i have a beissbarth wheel alinement system. (camber/caster/toe)
charge £40per hour (forum/trade rate) if everything is free'd off can usually do all four wheels in and hour and a half.
obviously if everything is rusted soild it takes a little longer
Regards
Will
