Strut top tools
  • Graham
    • 1622
    Strut top tools
    Hi all, could someone please post pics of the strut top tools to remove the top mounts, also could you give me the dimensions of the tool i.e. A/F size and depth.
    Graham
  • Glen Chamberlain
    • 375
    I've modded a 1/2 inch drive deep socket which i used sucessfully? PM me if you wanna borrow it? I think it was about a 13mm if i remember? With the end ground down to leave two lugs?
    Money is everything! Second to Power of course!!! But money breeds power??
    • Graham
      • 1622
      Cheers Glen but if is as simple as that i will make one at work as i have a few deep reach sockets, cheers for the info though
      Graham
      • Martynf
        • 1885
        Graham, I can positively say that the 'proper' tool aint worth it!! I did my tops mounts today with the proper tool, and the bloody thing broke with minimal torque applied!! I tightened them up with a screwdriver, tapped with a light hammer, worked better than the damn tool!!
        Martyn
        Martyn
        www.vagparts.com
        • Graham
          • 1622
          Cheers Martyn, i will contact you soon about some strut tops for the car, (will have to see how much christmas stings me )they are most definitely sh*gged, i fancy a nice set of blues.
          Graham
          • Martynf
            • 1885
            :-) no problem!
            Martyn
            www.vagparts.com
              WOrd of warning on the use of a screwdriver to nip up the top inner nut (in lieu of VW524) is that you can well and truly shag this nut if it is brutalised. I met this before and the pisser is that the proper tool is not fully effective at tightening such damaged nuts.
              Paul
              • martinjs
                • 3205
                Graham, ive made a tool for the slotted nut, used am M14 nut and milled 2 flats, 3mm deep, leaving the 'lug' 5mm wide in middle.
                theres a pic in this thread
                pic
                martin
                • martinjs
                  • 3205
                  Does anyone know anywhere where i can get the socket for the strut top nut, 22mm one with cut out in it...VAG3078....or are they cheap enough from dealers?
                  • Graham
                    • 1622
                    Cheers Martinjs, i will knock a few up on monday if that is all they are, no problem
                    Graham
