Last few days I've noticed that occasionally, when manoevering at parking speed and using full lock, there will be a strange "thunking" noise coming from the front when you engage full lock and then apply a bit of throttle to move. Don't tell me, is this the damned top strut mounts going already ?
Thunk noise on full lock
Am curious what this is, mine doesnt do it, but i remember it being something to look out for when buying an S2, as i tested it on all the cars i went to see.
There was a really really nice black metalic S2 in Kent i loved, but was oil leaking from engine and this clunking on the steering... had everything from memory, aircon, sunroof, the lot!
Might be steering compents worn? damper arm?Ant
2011 Kawasaki Z1000
A common test for the CV joint is to drive forwards on full lock, then reverse on the opposite full lock.
If your car clonks under this test, it is usually the CV joint.
Cheers n
Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey
With every option available
(except a towball)Comment
i've got an similar issue. however, i'm pretty sure my dampers are shot. might be worth a look.1993 UrS4...aka the rocket powered living roomComment
I've found two main culprits for clunks on full lock, both tend to happen when you are turning the steering whilst you're stationary - parking, etc.
The front springs can move on the spring perch, this tends to happen under maximum twist as you approach full lock. I have Konis, not sure if this is common with them?This got quite loud on my car until I jacked it up and checked out the springs. I moved them back to contact the stops and the noise went away. Unfortunately, it had a habit of coming back until I fitted Tim's top mounts. Not sure if the mounts fixed it or it was just coincidence
The other clunk I found was the droplinks, a bit of wear in these and you can get clunks and knocks while driving and on full lock. Both are easy to check when the front end is off the ground.91 Modded 3B
14 A6 Avant Black EditionComment
On a Ur quattro its generally the wheel bearing that moves in the leg, most people think it's springs, top mounts, "A" frame bushes etc etc, but it is the bearing that shifts between the "C" clips, might not be the same on an S2 but worth a look...
I had this on my Ur Quattro and it has come back. I also got it on my s2. On my UR it was the spring had moved a bit causing the clunk. How can u stop the spring from moving? cheers3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips
(just need the RS2 Airbox)Comment
I have just had the same fault cured on my S2. The nearside wishbone bushes were U/S. With the car ramped and weight off suspension, the wheel could be moved sideways about an inch and a half using large levers. I opted to have the whole unit replaced ( and have the old one for refurb ). Lovely and quiet to drive again and roadholding/handling back to "quattro" levels.Comment
Mine had it a couple of times. It were the top mounts that were worn.Comment
But not always
