best lowering solution?
  • tom
    • Dec 2004
    • 282
    i want to lower a little my S2 Coupe ABY. i mean about 20-30 mm all round. was looking for bilstein sprint shocks but seems that they fit only rear becouse of thread difference. what about front then? what about springs?
    any solutions Guys?
    If you use the original springs the ride height will remain the same. Changing the shocks can only affect damping rates. Only way to lower the car is to fit shorter springs. H and R seem to be the favourite round here. I've kept the standard springs and therefore ride height myself (roads are pretty bumpy round here and I need all the suspension travel I can get!) and fitted Koni Sport dampers which give a more controlled ride than the stock shocks (which were worn out anyway..) A stiffer front ARB is also a good mod to do as it controls roll without affecting ride quality too much.
      Re reading your post I see you may be talking about changing the whole strut? Someone has done an adjustable coilover conversion, you could try a search.
      Adjustable coilovers would mean you could dial in the ride height you want.
      • dan_b
        • Sep 2003
        • 3670
        As Newsh says, H&R springs offer the "Tried and Tested" lowering route - I have this on my S2 - it's quite a big drop and it's significantly stiffer than stock, but it does the trick! I have Koni shocks, but there are others.
        • tom
          • Dec 2004
          • 282
          how big the drop is with H&R springs?
          • dan_b
            • Sep 2003
            • 3670
            I'm not sure actually, sorry!
            • FITZY
              • Sep 2004
              • 194
              Mines 50mm if that helps
              94 S2 Avant, Crystal Silver, slightly modded
              89 Vw Golf mk2
              12 Mercedes e250cdi, silver, daily commuter
              • T2Andy
                • 1903
                The drop is 40mm rear and 30mm front which gives the perfect look the ride is ok to
                and im running standard shocks.
                • s2_southwest
                  • Oct 2004
                  • 823
                  Bilstein part no.s
                  Bilstein Sport.
                  Front: PE3-3086 (M55 thread) All S2
                  Front: P30-3005 (M52 thread) Non S2 coupe
                  Rear P30-3017 All Coupe (S2 and non S2)
                  Bilstein Sprint.
                  Front: P30-3006 (M52 thread) Non S2 Coupe
                  Rear: P36-3058 All Coupes
                  I have Bilstein and H&R. had the problem of the incorrect sprints being supplied for the front. I really cant remember what i have on the front now. deffo coz the p36-3058 on the rear. i cant find out and let you know on tuesday, cheers
                  matt
                  Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
                  • tom
                    • Dec 2004
                    • 282
                    s2 southwest, are You sure with the numbers becouse i have them different from bilstein catalogue
                    • s2_southwest
                      • Oct 2004
                      • 823
                      They could well be the right part no.s that you have Tom, im sure mine are the B8's which are the sprints. i will check with the guy i got them thru coz i was away from home while a garage fitted them and they had probs with them not fitting them and they sorted it while i was away. will check on tuesday and get back to you.
                      cheers
                      matt
                      • s2_southwest
                        • Oct 2004
                        • 823
                        p.s. The problem was that Bilstein Uk told my motorsports supplier which part no.s i needed, they said these will deffo fit the s2 coupe (91). They came and they were wrong, so they sent out some other ones but as they didnt come through me as i was away i forgot to ask what the 2nd lot they sent out were...Problem is even bilstein arent sure what fits what. There are two sizs, 55mm and 52, just cant remember what one fits the early ones, ive got a feeling its the samller one you need for early s2
                        • stevieyid
                          • Apr 2005
                          • 2251
                          Can u just fit the h+r springs to lower the ride height or do u need to replace the shocks to u? I would like to lower the ride height but dont have the money to buy do the full conversion
                          3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
                          • T2Andy
                            • 1903
                            [IMG]Can u just fit the h+r springs to lower the ride height or do u need to replace the shocks to u? I would like to lower the ride height but dont have the money to buy do the full conversion[/IMG]
                            Read my post stevei
                            • tom
                              • Dec 2004
                              • 282
                              mine is S2 coupe ABY november 94'
