hi could someone please tell me the ideal setting for the tracking and wheel camber for the s2 please!!!!!!!the local garage has the details for a standard s2,but if the wheels/suspension are different will this to change the setting,and from other drivers experience what are the best settings
thanks for the help
dean
dean
nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
thanks jamo would these be the ideal settings though or have other s2 drivers found any other settings to be better.Sorry to be asking this but a want to get the car all sorted in this department after replacing all the suspension parts!Oh also for setting the wheel camber up can this be done at most garages that do tracking?
thanks again
dean
for some reason i cant open up the above link and really really need the settings for tracking/camber as the car is going off in the morning to be sorted!Could someone see if they can open the link and then post the setting please it would be a great help!!!!!
thanks guys
dean
ahhhh!if anyone could find the settings for tracking/wheel camber of what information i need to take to the garage and post it before morning it would be a great help!!!!Or open the link!!!!
thanks
dean
thanks mike but i think the settings are the same on s2-central!dont suppose someone could explain the setting to me for toe/camber as i have no idea what it all means and it would be nice to understand!I always thought that wheel aligenment was worked out in degrees???If someone could run me through the setting so when i go back to the garage i can quiz them to make sure they have done their job right!!!!!!!!!!!1
thanks guys
dean
Probably true on our road cars - but if there was any camber in the standard setup, a wider tyre (especially on a larger diameter wheel with lower profile rubber) would probably need less camber or else it would lose some of the effective footprint. The problem is, the change is probably too small to adjust for, and the real solution is to set a baseline and then go testing, see what happens. Generally we don't have time or money for that kind of thing, and it doesn't matter enough for road use - if it did matter that much we would need different setups for the wet and the dry!
__MDC__
Martin Cutting
more problems the garage has rang and said they cannot do the rear camber as their is no adjustment on the balljoints???But is the adjustment on the ball joint or the wishbone?i have had new ball joints fitted and maybe they are the wrong part and have no adjustment!any ideas,oh and the camber is wayout so ithey said!
thanks
dean
