Hi all
Well a new year and more stuff to do on the car. Can anyone help me pinpoint the source of my recently aquired noise.
It started about two months back and is slowly getting worse. It only occurs on the LH side front wheel area and is a fairly metallic klonk noise that only occurs when I pull off, and to a lesser extent, when I stop. The car has new blue top mounts (4 mths ago) and if I jack up the front and tug about on everything nothing seems to have any play (that I can see). I have also recently replaced the ARB bushes (two split rubber jobs) and I took the front brake bits off and made sure all was tight (it was). I have also check that the top mounts are still tight and they are.
Could this be sub frame bushes ? A-frame bushes/ball joint ? Engine mount ? Any ideas ? I don't really want to do a trial and error method if I can help it.
Thanks
Andre
Thanks
Andre
