H&R's for Coupe
    H&R's for Coupe
    For those who have already fitted them.
    Do these look like the right springs for the coupe?
    part no
    • AbsS2
      • 285
      Not sure on part numbers, but mine are blue for what its worth
      Coupe
        Anyone know? Cheers.
        Could it be they are diff spring rates for colours.
        Do the spring shapes look right also?
        • dan_b
          • Sep 2003
          • 3670
          Mine are blue too
          • JariP
            • 192
            I don't know if H&R does it different way than others, but shouldn't those front and rear springs have about the same shape? Standard one's do and my Konis do and actually that Koni kit has four similar springs (same part number all four springs). Front and rear struts are about the same, so I wonder if those two with smaller diameter even fit the standard strut...
            • Doug_RS2
              • 3847
              Blue ones form QST - £165+vat
              H&R Springs:
              29 939 VA (Front)
              29 939 HA (Rear)
              And mine are blue
              • Doug_RS2
                • 3847
                I agree with JariP - When I got mine I had to check the numbers to see what were the front and rear ones as they are very similar - only a cm or so(can't quite remember) difference in height off the car.
                HTH
                  looks like i may have been sent the wrong ones then. Will give AMD a call tommorow about them.
                  • sal_s2
                    • 1287
                    They are definitely the wrong ones for a coupe.
                    Mine were the same shape front and rear, only the rear ones were slightly shorter.
                    They look like avant ones to me.
                    • S2 Ant
                      • 3682
                      Well the codes quoted by Doug dont match ur springs either greg....
                      Would def give them a call
                      Ant
                      2011 Kawasaki Z1000
                      • s2driveruk
                        • 12696
                        I got mine from AMD and they were a special order from the factory shipped direct as the springs come off a H&R kit rather than specified in any catalogue as just springs on their own for the S2. Only the RS2, 80/90 Quattro and S2 Avant are listed if i remember correctly. Mine are blue too and were £239 inc vat and delivery if you want some kind of price guide....
                        Those think ones greg look like they would fit over a shock rather than a strut insert....
                        Cheers,
                        David
                        1992 3b S2 Coupe
                        • 91_S2
                          • 612
                          H&R Springs:
                          29 939 VA (Front)
                          29 939 HA (Rear)
                          And mine are blue
                          How much did your springs drop the car? Be interested to hear from anyone on that.
                          • Doug_RS2
                            • 3847
                            link to thread
                            Look at the pics on this thread - top pic is standard suspension, middle pic is H&R/koni suspension.
                            When I got mine AMD were a lot more expensive the Quattrosports - and QST usually have them in stock.
                            • 91_S2
                              • 612
                              Cheers Doug,
                              Nothing could say it better than those pics. I think the ride height with the H&R's looks Gr8. Getting rid of that empty space between the tire and the wheel arch somehow gives the car a cleaner line. Subtle but definately an improvement.
