Compact Electric Power Steering Pump?
  • #31
    No probs
    OK Here are a few shots I took this afternoon of a proper race proven set-up: 997 RSR. This car completed the WEC in 2012
    The pump is a lot bigger than you think. There is no oil cooling. I would need to check the wiring schematics but I believe this is a "dumb pump" as Des has explained.
    • #32
      Alex - thats brilliant - what a lovely clean install too - what is the purpose of the little reservoir bottle feeding into the top of the EPHS pump ?
      If a full duck WEC car doesn't need cooling on the hydraulic fluid, then I certainly won't !
      • #33
        It is just an overflow bottle. I has never has anything in it I don't think.
        • #34
          Oh right - like old school plumbers central heating system with an expansion tank ;-)
          • #35
            2012 wec car....which one?
            1992 3b S2 Coupe
            • #36
              JWA-Avila No.55
              • #37
                So is the Merc pump not worth it then?
                I'm putting a 20vt into a different brand car and if I can use the merc pump to do the power steering I think I might go that way than have to mess around more with the audi pump tbh. I want to try keep as much of the stuff behind the front strut towers if possible.
                I'm sure there was another member here who put a pug version on his avant and had the pump by the diff with lines running to the front?
                • #38
                  Kiku Guys , what about remove old hydraulic pump and system include brake bomb and replace it with Opel Astra/ Zafira power steering pump? Only change brake booster (or keep them OEM) ? Any experience? Maybe i missing some point, but i really to take off that old hydraulic system and have more room for intake and other things on engine bay?
                  From what car is good to fit a vacuum brake booster?
                  Audi Coupe Quattro 2.3 20V
                  • #39
                    lots of people have fitted the astra pump. me included...
                    Along with a D2 S8 vacuum brake servo and reservoir...
                    edit: pic
                    • #40
                      LHD_kid : really nice...is that part number 13105727 ?
                      But that D2 vacuum booster needs some adapters?
                      • #41
                        not sure of the part numner, was from astra g I think. I will check.
                        No adaptors needed for the servo. only an extension for the rod to the brake pedal.
                        • #42
                          Thanks, so u you have that dual stage booster from A8. Please let me know about that PN of that pump...there is so much pumps around
                          • #43
                            servo
                            https://rover.ebay.com/rover/0/0/0?m...2F153171208408
                            Audi A8 S8 D2 4D Brake Servo 4D0612105F 4D0612107B 4D0611021B
                            I'll check pump...
                            • #44
                              Thanks... I need to use a TDI vacuum box, because of different bolt pattern, A8 have 2 bolt pattern
                              • #45
                                you need an adaptor to take the 2 bolt patern
