Compact Electric Power Steering Pump?
  • Dobby84
    • Feb 2011
    • 1169
    Originally posted by LHD_Kid
    servo
    https://rover.ebay.com/rover/0/0/0?m...2F153171208408
    Audi A8 S8 D2 4D Brake Servo 4D0612105F 4D0612107B 4D0611021B
    I'll check pump...
    Can that servo be used on a RHD?
    Been wanting to switch to servo set up, delete the PAS pump and ABS system on my track car build for ages now.
      Not with the stock intake plumbing, unless you modify the bulkhead and pedal box - the tandem boosters need an adapter to bolt on since the bulkhead / pedal box on the B3/B4 is 3 hole pattern on a smaller PCD.
      • Dobby84
        • Feb 2011
        • 1169
        Just bought an Astra electric pump to install soon.
        Has anyone got any info on the wiring? How have you guys connected it up etc?
        What hoses have you used?
        • Audipwr1
          • Jan 2022
          • 20
          What is the part number for the pump
          • bluequattro
            • 2960
            I'm think my Cosworth Transit used a Saxo electric pump but sold it a few years ago so not 100%
            • 5cylinderman
              • Oct 2011
              • 367
              Bad Obsession Motorsport used a Mercedes A class pump on Project Binky. You will be able to see the size of it on YouTube.
              • struikie
                • May 2019
                • 314
                VW Polo 6R has an electic pump as well with built in reservoir:
                https://volkswagen.7zap.com/en/rdw/p.../4/423-423050/
                JW
                | project | 1993 Audi 80 VR6 turbo quattro |
                | daily | 2018 BMW G31 530d | 345bhp 770Nm |
                • Jaswan
                  • Apr 2011
                  • 760
                  #53
                  Has anyone had any success varying the speed of the pump (whichever brand/type) for less assist Vs speed?
                  I am interested in controlling an EPAS pump from my EMU black.
                  Jase.
                  • 5cylinderman
                    • Oct 2011
                    • 367
                    There are several rally car sources that sell a control box for the Vauxhal/Opel Corsa B and C. It uses a variable resistance pot which the driver can adjust, but over the entire speed range so no "city mode".
                    • Jaswan
                      • Apr 2011
                      • 760
                      #55
                      I was looking for a variable hydraulic pump.
                      Anyone experimented with this?
                      Jase.
                      • Tom_
                        • Oct 2007
                        • 1301
                        • Country: Czech Republic
                        #56
                        Is it possible to set EPAS from Opel or Volvo to some value? I have to run EPAS only on half assistance, so the draw of the pump will be half (40A). I have an issue my alternator is 115A and I can't change to a different alternator as my 7A crank damper is V belt style or to a different crank damper as my engine is already balanced with that 7A crank damper.
                        I have Maxx Race ECU, so maybe there is a slight chance of setting that EPAS through Maxx and keeping it on a certain value to keep the draw as low as possible with some small help.
                        Any thoughts?
                        Audi Coupe Quattro 2.3 20V
                        • Bowie69
                          • Nov 2013
                          • 2675
                          Surely it won't be drawing 40A all the time, that must be a peak value, surely?
                          • varia
                            • 821
                            • Current: United States
                            #58
                            Volvo EPS is fairly easy with maxxecu
                            MaxxECU supports the Volvo power steering found on the Volvo P1 platform.
                            But the pump/reservoir/bracket is huge and heavy, also needs a lots of amps
                            The Polo pump seems smaller, more compact and takes less Amps.
                            But Im not sure about the communication, steering angle sensor example.
                            • Tom_
                              • Oct 2007
                              • 1301
                              #59
                              The peak could be around 80A, so its a plenty.
                              https://www.maxxecu.com/webhelp/can_...rsteering.html
                              I know that Volvo pump could be running through Maxx...but i am not sure if there is any option to keep assistance=voltage as the user wants.
                              • Bowie69
                                • Nov 2013
                                • 2675
                                If it's not doing work, there won't be a high current draw, there's not really any way around that -think you need to re-check your assumptions around that, or do some testing.
                                I strongly suspect 115A alt will be plenty.
