koni rear shock question
  • vonbeck
    • 2455
    hi everybody i`m after a set of koni rear shocks prt number i think is k862433s is this correct and if so does anybody know where to purchase them demon tweeks have them for £263 a pair is this about right, and also i`m undecided about the springs, either go with standard or h&r one`s but im having trouble locating any and if i did stay with standard springs would it be better to get new ones? i use my car as a daily driver and dont want a back breaking ride any advice would as always be great
  • aelred
    • Jan 2005
    • 761
    I can get you the Konies for 180 GBP all in for the pair plus any postage to you.
    Aelred
    • mcandmar
      • Apr 2004
      • 5118
      I ran Konis with stock springs for a year or so and it was a nice setup, much better body control with the Konis and a reasonably comfortable ride. I'm running with H&R's now and its a lot more crashy over bumps, you really notice the reduced suspension travel if you have to drive over speed ramps every day. If you are unsure try it with stock springs first.
      Oh and have a search for shock settings as you have to adjust the rears before you put them in, i found a 1/2 turn was about right with stock springs, 1 turn with H&R's. But everybody will have there own preference.
      Mark.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
        Koni shocks stock springs great setup
        • vonbeck
          • 2455
          thanks guys so i guess i use my original springs for the time being or would i be as well replacing them with new one`s bearing in mind the cars only done 63000 miles ta
          • blown_vr6
            • Apr 2005
            • 406
            Do you guys remove some of the bumpstop when fitting the H&R's?
            General rule of thumb is if you lower the car by 40mm you reduce the bumpstop by apporximately the same amount to retain the same suspension travel prior to lowering the vehicle.
            Its obvious what happens if you do not remove some of the bumpstop.
            Over the last couple of days ive been going over my front suspension with a fine tooth comb as i have a mysterious rattle from the nearside.
            I have Koni & H&R's and upon removing the front struts the bumpstops are still at their original length - i have removed material to the first rib which equates to approximately 25mm or so - result is more travel and better ride.
            'If you ain't broke it you ain't trying hard enough'
            Oh sh*t i broke it
            94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
