Thanks John , much appreciated
more problems Mot failure, rear subframe
Originally posted by 220bhp View Post
Thanks for the advise.
My problem is the car is in my mates garage and I am on a time limit.
How much work is involved in removing repairing and replacing .
Also what was the cost
Good luck!sigpic
1992 3b S2 Coupe
Originally posted by 220bhpThanks
Sent from my SM-T800 using Tapatalk
ABY Cricket Green Pearl Coupe, blk leather
THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
Originally posted by vonbeck View PostJust be carefull with powder coating stuff as if and when it chips( and it will) water will get underneath and wil rot I've done both my subframes and used hydrate 80 then about 3 coats pro 15 chassis black and will probably see me out
Originally posted by steve briance View PostIs there a reason NOT to galvanize struts? The only thing i can think is maybe the threads fill up with metal but that can sorted easier than rust in the bits you can't get a wire brush on.
I'd be apprehensive getting the struts done, unless someone with a degree in metallurgy can say that it'd be 110% ok. !
I don't have a metallurgy degree but do know that electro plating and galvanising can affect strength of steel but it is higher strength grades of steel that are affected. Think 10.9 and 12.9 grade steels for bolts. 8.8 is fine to galvanise and plate. The acid pickle phase of the process causes 'hydrogen embrittlement' hydrogen absorbed into the surface of steel makes it brittle. Why its only high strength steels affected I don't know.
I doubt the steel used for subframes and struts is high strength and based on the fact b3 chassis parts are galvanised makes me think it is an acceptable process that is probably not more wide spread due to manufacturing costs. As enthusiast restorers, that issue goes out of the window doesn't it?!
I might investigate galvanising struts but would paint afterwards to prevent the visible oxide layer building up into the dusty surface you sometimes see on galv' parts.
Thanks for all the advise.
I have started to take the sub frame of and. some of the bolts are seized, so I have covered them in penetrating oil ,
Has anyone got a list of parts required for a refurb.
What bushes ,OE or poly . Which bolts should I replace.etc
Sent from my SM-G920F using Tapatalk
Sub frame is of now , but it’s in bad shape .
I will post some pics tomorrow. Not sure if it’s repairable.
Is the rear sub frame unique to the s2 coupe, or can I use the sub frame of any other Audi model and weld the
Anti role bar brackets on.
Goodazz has one on here for sale. Looks good, but it's in Lithuania so postage will be considerable. Depends what deal he will do for you.
I have received quite a few parts from Latvia, no problem at all and quick postage.Last edited by Tractor Dave; 9 March 2018, 17:29.Nothelle S2 Avant
Originally posted by 220bhp View PostSub frame is of now , but it’s in bad shape .
