When I was designing a hollow bar, it was approx. half the weight but that was just the torsion section rather than the whole thing. More like 5kg but best off measuring one I guess.
They will allow for some tuning of the chassis but will have to be stiff to make much of a difference. Running a 28mm hollow bar would work well.
It's not the design, that the easy part, it's the material and any heat treatement that is required that's where the skill comes in. Could do steel tube with arms, I was looking into a modular system some time ago but again, couldn't find a supplier. Could just get it made and see how it does...
I'd be aiming to make something suitable for about £200 + £50/extra bar. Depends how you do the bushes I guess.
Just to close my pursuit up.
I brought two kits from Sellholm Sweden.
There is no way you can build something as good as they and offer as much adjustment. I think if you want these Blades and you are serious about making a S2 handle you have to bite the bullet and buy the real deal!
