Removing shocks from struts
    i used the stilhson method after wire brushing the ca nuts to loosen anby rust abd a goods soak in oil for a day or so, caps were reusable too
    • dhali7376
      • Nov 2009
      • 301
      I used heat and a pair stilhsons too.
      • S2TORNADO
        • Jan 2008
        • 620
        Heat helps but you need to be a bit wary that there's a shocker inside.
        • dhali7376
          • Nov 2009
          • 301
          yes I used a heat gun. Took longer but a safer option .
            If there is interest I can make these caps in stainless and a suitable tool to suit: If so start a list below so I can get a feel for quantity
            Alex
            • adam g
              • Feb 2007
              • 445
              For info, I discovered that if you buy bilstein shocks you get new caps with them to suit the new shock.
              Sent from my F5121 using Tapatalk
