Coupe quattro rear tie rod lengths. 20v vs 10v
  • 90quattrocoupe
    • Nov 2003
    • 771
    Originally posted by varia
    buy adjustable, call it a day
    The only problem with adjustable Chris, is they do not come with boots.
      And in many cases don’t fit properly
      • varia
        • 821
        • Current: United States
        mine came with boots, and did fit on my friend cq and on my urq
        • Praski01
          • May 2022
          • 1
          Hello guys, back to subject ?‍?, I have 2.3 Quattro 1990 coupe. Any know part number rear track rods ? Plz
          even in Germany they struggle with it.
          if you have links where can get them from ?
          thank you
          • Bowie69
            • Nov 2013
            • 2681
            So........ a few years have passed, and my rear tie rods have some significant play in them, has anyone worked out a good solution for replacement 893501499B or 893501499A arms?
            As I understand it the two variants are for rear anti-roll bar equipped vehicles and not, but the outer bit which actually wears is the same, therefore if we can solve that, we can fix it for both.
            So... any thoughts other than the E36 one mentioned above? I don't think it has the right curve in it as Alex suggested, so would be doubtful it would be correct in all circumstances.
            A bush is quite easily made, so it is just the ball joint on the other end we need a solution for, as far as I can see?
            Are there any places out there that will fix a ball joint by, for example, machining and fitting an over-size joint?
            • Bowie69
              • Nov 2013
              • 2681
              No takers then?
              So... taking things further, I've found a good resource to try and find compatible tie rods, does anyone know what the thread is on the inside of the tie rod where to connects to the adjuster?
              That would really help narrow things down a bit.
              Thanks
              • Bowie69
                • Nov 2013
                • 2681
                Doh, I see it mentioned above now, M14(!)
                That helps, unsure if fine or normal thread pitch, but I guess I can check that here on mine.
                • Bowie69
                  • Nov 2013
                  • 2681
                  For reference they are M14x1.5. Still working on a solution.
                  • ullbsorya4
                    • Oct 2022
                    • 9
                    • Home: Barbados Current: United States
                    #24
                    Did you find any solution to the rear track rods. Because I am also looking for a set for mines. My coupe quattro came with a rear sway bar. But the bushing and the ball joint are shot.
                    • Bowie69
                      • Nov 2013
                      • 2681
                      I'm experimenting with the earlier cars track rods, I will feedback when I know more.
                      • Bowie69
                        • Nov 2013
                        • 2681
                        More than a year on I can confirm the earlier car's track rods have been working for me. I measured the thread engagement in the adjuster as 30mm from either end which I think it sufficient, though I am still tempted to look out for some track rod extenders (like the drift guys use on the front).
                        This is a CQ20V so has a rear anti-roll bar as the added complication, and different subframe mounts.
