Total Under Car Refresh/Refurb on RS2
  • rustybullethole
    • Aug 2013
    • 531
    Time for an update, this time on the fuel lines, I had asked Nick to re-new all fuel lines under the car as they looked a bit sus and a bit rough, close to the pipe clips. Got a call from Nick yesterday that as he removed the old fuel line from the clips the pipes were actually fracturing and falling apart, as can be seen in the pictures. The new fuel lines and fittings are being manufactured for the car by a company called A-TEC Fluid Systems (think F1 and Motorsport). The upshot was that the car was really living on borrowed time with respect to the fuel lines, you can see below in the pictures. I will try to get some pictures of the new lines once they have been fitted, or even some before shots too.
    Below you will see some really nice finished pictures, i will keep them coming through as i receive them
    • John.
      • 2615
      • rustybullethole
        • Aug 2013
        • 531
        Tractor Dave Thanks very much for your help this morning.
          • Dec 2017
          • 5983
          You are very welcome. You should get it tomorrow
          • rustybullethole
            • Aug 2013
            • 531
            Good stuff, thanks again
            • ThatGUY
              • Sep 2004
              • 794
              Good call to have the fuel lines replaced. Can't wait to see the new ones.
              //-\\ ((_)) //)) //
              • steve briance
                • Aug 2014
                • 1455
                its amazing how bad the fuel pipes can get without leaking isn't it?!
                Mine snapped inside the rubber mounts exactly the same as yours, the incredible timing of that was that they did it on the driveway after getting back from an MOT pass!
                The corrosion was hidden inside the rubber and only surface rust outside of that which didn't look too bad.
                replaced mine with 8mm kunifer pipe - factory look, fits into the rubber mounts which were still perfect, job hopefully longer lasting than steel...
                • kenneally_mark
                  • Jan 2018
                  • 55
                  Epic work on this, well done Martin!
                  • rustybullethole
                    • Aug 2013
                    • 531
                    Thanks Mark, I'm really looking forward to collecting the car on Tuesday.
                    • rustybullethole
                      • Aug 2013
                      • 531
                      A couple more pictures from the refurbishment, its just about all done now, just a bit of a shake down then MOT & an alignment on Monday, i hope to pick it up on Tuesday
                      a picture of the state of the fuel lines coming off
                        Lovely job
                        • rustybullethole
                          • Aug 2013
                          • 531
                          Thanks
                          • rustybullethole
                            • Aug 2013
                            • 531
                            Bringing this thread to a close, i went to pick up the car yesterday and was very very impressed with the result as this was the first time i had seen the car in the flesh since 1st May as that is when i dropped the car off at Tech-Sport Engineering in Market Harborough, the magic man was Nick. I had an hour or so just going over the car with Nick as he showed me all the issues that he had along the way and how he had over-come them, this guys attention to detail is very impressive, he kept in contact with me over the time it was being worked on.I could not have wished for a better finish and result on the RS, its fabulous. His workshop area is lovely and it can be noted that he has a very professional and experienced background in Motorsport
                            The drive home was great, the weather was great, only issue was i was just a bit mindful that having all new brake discs, pads and refurb calipers that i kept my distance from vehicles in front as i didnt fancy any dramas.
                            Some pictures of yesterday
                            • rustybullethole
                              • Aug 2013
                              • 531
                              The man himself Nick Hogarth, Tech-Sport Engineering Market Harborough
                              • John.
                                • 2615
                                You sound a happy man!
                                Can't see your yesterday pics
