3-Bolt Ball-Joint Versions and related info... a more definitive guide.
  • Lago Blue
    • Jul 2009
    • 843
    Dustin,
    I like that you marked each arm L and R to keep where they were going to now go, straight in your head!
    Please post a profile photo of your UrQ showing a rear wheel's fore/aft position in the fender-arch opening using the above parts, IIRC this worked out very well.
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      #32
      Having a problem getting the right part for my 93' s2 Avant with cast/forged wishbones,
      Failing MOT, need a new left-side Ball-joint.
      ETKA states part# (Left side) to be 895407365A, and the part# is confirmed from the part# from the car, but my local dealer hasn't this
      Now I've found "Corteco 49401196" that claims to be "895407365A compatible", anyone able to confirm this ?
      • Lago Blue
        • Jul 2009
        • 843
        Hi sir pfi,
        I cannot, however perhaps the vendor can send you photos and you can then judge for yourself?
        • M2ki
          • Aug 2015
          • 547
          Seems like a correct part. It must be new old stock, because corteco has stopped making them some time ago. Most of them are, locally i can find only delphi and some ruville parts, which also is probably new old stock.
          Autodoc shows only 2 pieces left.
          1989 Audi 80 Quattro
          • pfi
            • Jun 2016
            • 274
            • Country: Norway
            #35
            My local dealer came up with this (TRS BJ117) as a replacement :
            looked promising, but when I got it, it's not the same caster offset as 895407365A
            The box it came in was labeled 8A0 407 365 and I don't understand that it's correct ?
            Isn't 8A0407365 a replacement for 895407365 ?, and, if so, shouldn't it have caster +2.15° ??
            anyway, now I've ordered "Corteco 49401196" (Thnx to M2ki)
            I'll post result when getting it
            • Rikki Kitto
              • Feb 2010
              • 6276
              Watching with interest as I have ended up with two different ball joints on my car which makes getting it tracked interesting to say the least
              • pfi
                • Jun 2016
                • 274
                • Country: Norway
                #37
                Rikki Kitto
                If the difference is different caster then You've got a "problem"
                If it's only the height it's propably ok ... (as long as You have clearance between wishbone and shaft)
                What whishbones do You have, pressed plate or cast/forged ?
                different ball-joints ...
                • Bowie69
                  • Nov 2013
                  • 2675
                  Is this just S2s or are all coupes affected?
                  • pfi
                    • Jun 2016
                    • 274
                    • Country: Norway
                    #39
                    dunno,
                    My first impression was that all B3 (not ACOQ) had 1.15° caster, then all B4 (incl ACOQ) was upgraded to 2.15° caster,
                    but now, after having a look at the "TRS BJ117" I'm not sure anymore ... :/
                    also,
                    what wishbone You've got also "counts-in", pressed-plate or cast/forged
                    the "problem" for me, is for the cast/forged wishbone for my 93' s2 Avant, my 91 s2 ACOQ with "pressed-plate" wb's, no problem
                    • Rikki Kitto
                      • Feb 2010
                      • 6276
                      Rikki Kitto
                      Cast forged and I think I have one ball joint correct a d one for pressed type wishbones
                      • pfi
                        • Jun 2016
                        • 274
                        • Country: Norway
                        #41
                        afaik if they're both the same caster it shouln't matter beside a possible clearance problem between wishbone and driveshaft, if different caster, You've got a "problem" ...
                        I've ordered a "Corteco 49401196" and will update info here when I get it ...
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          My problem is one of my front wheels sits slightly further out than the other
                          • pfi
                            • Jun 2016
                            • 274
                            • Country: Norway
                            #43
                            "further out" shouldn't relate to ball joint ?
                            AFAIK ball joints only affect caster and clearance between whishbone amd driveshaft.
                            or, have I missed smthng ??
                            • Bowie69
                              • Nov 2013
                              • 2675
                              Well, you can adjust the 'outness' of the wheel, as the bottom ballpoint is adjustable to set camber.
                              It has quite an effect.
                              • pfi
                                • Jun 2016
                                • 274
                                • Country: Norway
                                #45
                                Yep, but that doesn't relate to the any specific ball-joint, all camber adjustments is "same procedure" regardless of whisbone-"type" and ball-joint ...
                                as "stated" earlier, ball joint caster is the most important to keep equal on each side.(more is better)
                                second up is clearance between wishbone and driveshaft. .. capiche ?
                                I'm using a simple and cheap tool, avalable on eBay and Aliexpress, to keep my camber setup (equal) aligned :
