Replacing bolts for studs and nuts
  • piotr
    • Jul 2012
    • 1470
    • Home: Poland Current: England
    Im struggling to find info on what's involved in replacing bolts for studs and nuts on S2 hubs .I just hate fitting wheels back on ,trying to align discs moving about,spacers and then wheels that is dropping and scratching new paint on the caliper
  • AndyP
    • 6049
    I did this on mine years ago, makes life so much easier. You need something like this, with nuts to match your wheels i.e. taper or conical.
    https://www.ebay.co.uk/itm/20-X-M14X...gAAOSwmFhbvREg
    I'm not recommending this as I was wary of buying off Ebay as you never know what they're made of, but I can't remember where I got mine from,sorry.
    • ajax1976
      • Aug 2015
      • 212
      I use a couple of these to avoid damaging calipers,
      https://www.ebay.co.uk/itm/ALLOY-WHE...IAAOSwMjpcDRFI
      • piotr
        • Jul 2012
        • 1470
        Yes i definitely want be buying something like this from Ebay
        • piotr
          • Jul 2012
          • 1470
          Thanks mate .it would defo make changing wheels easier.
          • K Simmonds
            • Dec 2007
            • 7627
            There should be a heavy duty plastic version of the above 'tool' in your OE tool kit along with a short 10/13 mm spanner and a double ended screw driver, studs are a much better option, though much more expensive for a decent quality set with both nut types. I use to run studs on my 3B S2 but now carry two of the OE plastic location tools instead in the kit's in the boot's of my cars except my RS2 which has studs as stock. I have a few of the plastic ones if you'd like one for the cost of postage.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • piotr
              • Jul 2012
              • 1470
              .Thank you very much for offer Buddy. I will try to find some decent studs and I I want find anything good then I will get back to you .
