S2 avant H+R lowering springs
  • Al Wyn
    • Nov 2006
    • 3746
    Want to sit the S2 avant a bit lower -40mm to be precise. Not sure which H+R springs either S2 or RS2. Anyone got them on or had them on with 225/45 17 s (pictures ?)
    Anyone got a `source` for good priced supplier ?
    S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
  • blown_vr6
    • Apr 2005
    • 406
    Alan - you drove mine on H&R's,
    Avant's run 'green' springs.
    'If you ain't broke it you ain't trying hard enough'
    Oh sh*t i broke it
    94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
    • alg
      • Apr 2004
      • 1160
      Alan, the RS2 springs are the same as aircon S2 avant springs. i.e. no lower. Its only a suggestion but wait and see what RS2 alloys with fresh dampers (if needed) feels and looks like.
      Lower springs can ruin the ride with firmer dampers for some.
      Colin Chapman (Lotus founder) always said firmer dampers rather than stiffer springs. He knew a thing or two about handling IIRC.
      Alastair
      RS2
      • Al Wyn
        • Nov 2006
        • 3746
        Yep cheers i did give yours a run up the road Pete i forgot you were running them, bit distracted because i was falling out the seat in the corners not for much longer `hopefully` eh
        • blown_vr6
          • Apr 2005
          • 406
          Alan lets be honest here.
          there is no way you could 'fall out' of any seat now is there??
          Oh sh*t i broke it
          • Al Wyn
            • Nov 2006
            • 3746
            Thought you were after something more suitable to sit on in your wagon from me Pete or maybe you had another source and fancy a battle via `sniper`?
            • rj scotty
              • May 2006
              • 2195
              My avant on H&R greens with 225/45/17
              ride is great and no rubbing
              BUT I DON'T WANT A NEW CAR!
              1995 S2 Avant, Volcano Black
              • Al Wyn
                • Nov 2006
                • 3746
                Just the piccy i wanted to see shows it sits nice and squat cheers
                • tobodestroyer
                  • Dec 2005
                  • 174
                  For what it's worth....
                  I replaced my lower H+R's with standard S2 (Avant with air-con) springs all round. The car handles so much better than before and I've got much more confidence in it when I throw it into a corner.
                  Ask yourself why the H+R kits are so cheap in comparison to the Audi originals. Quality usually comes at a price...
                  The H+R springs could easily be compressed by hand when off the car - the S2 ones wouldn't budge as they are much firmer.
                  Think carefully before making this replacement. (Note - I did NOT say upgrade!)
                  Pete
                  • blown_vr6
                    • Apr 2005
                    • 406
                    H&R's are variable rate springs which is why you can compress them by hand (well the progressively wound coils at least), they have to be to allow enough free length to reach the spring seats on full travel and yet lower the car.
                    Dont think the price of the Audi springs is anything to do with quality at all, you can get great springs for not alot of money and crap ones that are expensive imho - its all down to spring rate not cost.
                    Oh sh*t i broke it
                    • Bibby
                      • Aug 2004
                      • 1043
                      I've had my H&R's fitted new in March 2005. One is knackered already.
                      It's got slightly deformed, so the back end sits about an inch lower on one side than it does on the other. On closer inspection today, 3 of us concluded that they had possibly been fitted rather gashly too. The setup hadn't been rotated such that the ends of the springs met the stops.
                      So either it's the fault of install, the immense weight in my boot, or they're just sh*te.
                      Don't get me wrong, the setup with Koni's, alloy top mounts and subframe bushes, poly wishbone bushes and RS2 front and rear ARB's is great. But I won't be buying H&R springs again.
                      acidtrax
                      • Coxy
                        • Jun 2005
                        • 1090
                        Here's mine!!
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Coxy the car looks the mutts nutts
                          Chef
                            Originally posted by Coxy
                            Here's mine!!
                            Correction, here's the wifes!
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              Chef
