BC coilovers ?
  • adampug11
    • Sep 2017
    • 85
    BC coilovers ?
    Has anybody tried them? I have heard good things from a friend that had them on his M3. They are considerably cheaper than KW v1.
    adam
    Nothing good is cheap.
    You get what you pay for
    • Wrath
      • Jan 2011
      • 779
      From what ive read the KW V1 is crap so BC is probably not better. But KW v3 is something else according to the public.
      1995 Audi S6 - AAN (~350hp)
      2008 BMW 530xd (235hp)
        V1 is very good value for money. The spring rate & damping is well matched a very good compromise on a road car. V3 is only worth the extra expense on a track car, since in reality you will never use the adjustability on a road car.
        If you have the budget then of course you buy Ohlins
        • tango123
          • May 2017
          • 892
          I was starting to think they wernt very good, i've got some new v1's i need to fit at some point.
          • david1980
            • May 2014
            • 1025
            Whats the kw's go for now as Yaz used to be able to get good discount but not seen him on the forum in quite a while. v1's are on the list of purchases for mine.
            • rynaqui
              • Mar 2012
              • 2752
              • Country: Malta
              I have V1s and not happy with them at all, was going to go for V3s but I'm opting to fit a set of Intrax 1K2 with ARC once I'm done assembling.
              1996 S2 ABY Silver
              • david1980
                • May 2014
                • 1025
                why are you not happy with them? I know the roads are bad in Malta is that the reason or something else?
                • rynaqui
                  • Mar 2012
                  • 2752
                  • Country: Malta
                  It may be partly the roads which are to blame but the ride with V1s seems very crashy, I've snapped a lot of springs which means their life has also come to an end. I would recommend to at least go for the V3 which are supposed to be much better than the V1.
                  1996 S2 ABY Silver
