I bought and received a rear subframe that was meant to suit my s2, but the seller sent one without arb mounting points
Has anyone modded a rear subframe by adding ARB mounts to it? Would like to see pics of one done to have a go at it myself to make the purchase worthwhile.
So far after a quick check, the inner rear tire rods don't seem to fit into the brackets on the frame by about .5mm, and looks like the tie rods would have to be adjusted slightly shorter. These seem like a fairly easy fix, hopefully everything else should line up ok.
. Did an article in the VW/Audi car magazine on fitting a rear ARB back in 1997. One of the best mods I have fitted to mine. made the brackets and welded on myself and used the front roll bar from an early GT. Have the article here I can email if interested.
