Elsewhere on the forum here (in the stickies for suspension and steering) is posted the formula to convert spring rate units if you need it.
Not that it helps you directly (with your coil-overs) but in terms of rate, know that I have run some yellow H&R lowering springs apparently made for the stock struts of the type 85 Q's on my 1990 Q Coupe, which I've found are quite comfortable. So similarly, it may be that the B2 and B3 stock rates are quite close, and info on B3 rates may be more obtainable, if you're looking for comparisons.
