Steering Rack Leak
  • Steering Rack Leak
    After parking up yesterday after a rather spirited drive, I could smell what I thought was the clutch and then I could see smoke coming through the bonnet vents.
    A closer inspection showed a leak of hydraulic fluid out of the top plate on top of the steering rack. This had leaked onto the inner CV which had thrown it against the side of the engine block, hence the smoke.
    The two retaining bolts are tight. Is it just a case of the old 'O' rings needing replacing?
    Steve
    1990 RR 20V
    1982 SWB UR - RS2 Engine
    It will most likely be the o ring that’s worn Steve
      There are two seals, the centre bolt is the pre-load adjuster and there is an o-ring on that. There is a seal under the plate too.
      HTH
        HTH
        I've only looked to get the 25x2.5mm one, which is the one under the plate. It would be a good idea to replace both though.
        Steve
        1990 RR 20V
