After parking up yesterday after a rather spirited drive, I could smell what I thought was the clutch and then I could see smoke coming through the bonnet vents.
A closer inspection showed a leak of hydraulic fluid out of the top plate on top of the steering rack. This had leaked onto the inner CV which had thrown it against the side of the engine block, hence the smoke.
The two retaining bolts are tight. Is it just a case of the old 'O' rings needing replacing?
This gallery has 1 photos.
