I've not read the whole thread but I suspect you think it is more complicated than it actually is.
Undo 6 propshaft bolts before taking the handbrake cable off. This way at least you have some way of locking the rear axle from turning while you undo those bolts. If your handbrake isn't strong enough come up with another plan. These bolts were INCREDIBLY tight in my car and this was the biggest struggle of the whole job.
Undo the ball joints into the rear Hub carrier and disconnect the suspension from the wishbone.
Undo rear track arm at either end depending on what tools you have.
Disconnect roll bar drop link from suspension strut
Unhook the handbrake cable from their bracket on the subframe. If the route your cables take is underneath something then the will need disconnecting from caliper.
Leave calipers where they are.
Jack up trolley jack under the diff and support. (here will be about right to balance it the whole assembly)
Undo the 4 subframe bolts and lower it all down on the jack.
There is no need to undo the exhaust it goes over the top of the subframe and stays in place.
forgot driveshafts!
thanks
That made the day so much easier haha. And that I thought the propshaft/driveshaft or what its called was stuck, it just needed a tiny slap with a rubber hammer while my friend pulled the jack againgst him.
just had mine done, build with bigger axels,Cvs + whiteline swaybar
