Hi been a while but question need to replace a rear tie rod came up with 2 numbers 893 501 499 A or B, have trolled thro lots of posts but no definitive answer, 1993 aby S2
rear tie rod
Hi Sir,
I believe the difference is simply whether one has the original brackets for a factory Rr. A/R bar (a change which first appeared on the 1990 model year cars) on the sub-frame; their presence displaces the rod's inner mounting points inboard from cars not so equipped; this increases the rod's length requirement; and that presence or absence of said length is evident in the neck under the end-eye of the inner-most section of the rod appropriate to each type. These are the short-necked ones illustrated at 7zap, I suspect those would be the "A"'s. 1st photo is of a long one, likely a "B". 2nd photo, a short "A".
https://audi.7zap.com/en/rdw/audi+co.../501-501020/#1
A definitive answer is a little more work.
Edit: OK. here's a photo of the long-necked one for the with A/R bar cars, it appears to have the dealer sticker on it and you can just make out the front end of the letter "B" after 499.
Audi B3 Rr tie rod type "B".pngLast edited by Lago Blue; 30 August 2020, 20:31.
