S2 (ABY) subframe Q
  • pfi
    • Jun 2016
    • 274
    • Country: Norway
    S2 (ABY) subframe Q
    Failed MOT due to one rubber mounting in the front subframe (also other issues but far more easy to fix ...) .
    Have read that the subframes are adjustable, one fixed point and three adjustable, is that correct ? or have I been mislead ?
  • steve briance
    • Aug 2014
    • 1455
    That is correct but i can't recall which one is fixed. If you drop your subframe down to fot new bush you will be able to see which is the fixed mounting point. The others all float a little with free but captive square nuts in the chassis.
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      ok, thnx, but wasn't the answer I hoped for ...
      Any DIY for alignment ?
      • John.
        • 2615
        I'd be for measuring a line from a front mounting point (rear subframe) to a point on the opposite front side (possibly the rear mounting point of front subframe), then adjust so the measurements from each side are the same......if that makes sense ?
        I think it's one of the rear mounts that is fixed.
        • John.
          • 2615
          Just re-read your post, sorry I was thinking the rear subframe rear-most mount is fixed
          • pfi
            • Jun 2016
            • 274
            • Country: Norway
            My concern now is about the front subframe, but I guess the rear also have one fixed and three adjustable ?
            and, yes, may take some cross-reference measures but will it be accurate enough ?
            Mby I need a pro to get it right ?
            • John.
              • 2615
              4-wheel alignment for sure, but also you'd need to be sure that the operator is competent to be moving the subframe(s) !!
              ........or measure and adjust yourself so you know subframes are in line and square with the body, then get alignment done?
                • Dec 2017
                • 5983
                When you remove you will see it leaves nice marks on the mounting points. Just replace covering those marks
                • John.
                  • 2615
                  Good thinking Dave
                  ....and it'll show how a standard bush has a good contact area unlike poly.
                  • pfi
                    • Jun 2016
                    • 274
                    • Country: Norway
                    Propably not needing a 4-wheeler for now if I can get the subframe back in it's original pos.
                    I'll do a 4-whhel later when all other parts replaced.
                    As the original mountings is pretty hard to get in place, I'm planning to replace (all) with Powerflex (black-series)
                    • John.
                      • 2615
                      You're not wrong there!
                      • steve briance
                        • Aug 2014
                        • 1455
                        People do manage to fit the original rubber types somehow but, when I tried; i destroyed 2 mounts and snapped an M10 bolt trying to use one and some washers to drawer the bush into the subframe.
                        My poly bushes press in by hand.
                        Lovely.
                          I used Superflex when I did my subframes. They’re a bit quieter than the Powerflex.
                          • pfi
                            • Jun 2016
                            • 274
                            • Country: Norway
                            This one : https://www.superflex.co.uk/proddeta...=SF080-1797KSS ?
                            Have thought about these but have not found a dealer in Norway.
                            Powerflex has a local dealer nearby ...
                            How did You align the subframes ?
                            • John.
                              • 2615
                              Lovely.
                              Yes lovely to fit.
                              Does anyone have concerns regarding the design (or lack of) of the poly ? The metal insert/sleeve should ideally incorporate a "penny washer" where it contacts the chassis in the same way the original bush does?
                              Cheap to produce I'm sure but not cheap to buy.....but folks keep buying!
