where did you find the info on Nm for audi s2 ?
Complete sets of rubber bushings
Hi Ljubisa,
Not always. It depends on what that particular poly bushing has to do to function.
For sub-frame bushes, which in use they see no core rotation, they are there to simply act as cushions. Since rotation is absent there, no noise occurs and no lube is required (except perhaps externally for the install). However as poly is not a slippery material, if a poly bush's metal core must rotate (as with A-arm bushes, etc.), it wants to stick-unstick-stick...repeatedly as it finally allows rotation, if enough extra torque is then applied, and it will do this if no lube is present, as the lube becomes washed away, and if they are not taken apart and re-lubed periodically.
The reco'd lube from bushing maker's is going to be a silicone-based water-proof grease to avoid incompatibility with the poly. Despite the success some experience, noise relief must be thought of as temporary.
When you tighten everything , what should stay fixed and what should move/rotate ? Bushings /pins ? My arm oves up and down , should the my bushings follow that movement ? The arms are powder coated and the part the hold the arms to. So the outside of the bushings will rub agains the powder coated , do people remove the powder coating ? Or just lube it up ?
Ljubisa,
Pins should remain stationary. Bushes should rotate with the arms, not in the arms. In this case you should not lube the exterior of the bushes before installing into the arms. Bushings' outer body always rotates with the arms.
Your last two sentences above refers to which suspension arm?
Ljubisa,
Upper arm bushes work similarly, as the outer body of the bush rotates with the arm, and if made to face inwards (see photo), the large end of the red poly flange does not rub on the mounting bracket. The through-bolt is stationary and keeps the metal cores from rotating.
In this photo note re-use of the old metal cores from the correct OEM rubber bushes from this location, (which unlike cores from front lower A-arm bushes), each have a large OD integral flange (visible in photo, between red poly flange and small OD black tube of bracket) at one end. Arm has zero play front to rear. I was surprised that this worked as well as it has.
Original articles here:
https://www.audiworld.com/forums/aud...hings-2129366/
https://www.audiworld.com/forums/aud...hings-2784388/
B4 Rear Susp Upper Arm Attachment w:Poly bushes and OEM metal cores Screen Shot 2022-02-13 at 13.12.14.pngLast edited by Lago Blue; 14 February 2022, 12:34.
