Complete sets of rubber bushings
  • Complete sets of rubber bushings
    Is there a demand on complete sets of all bushings and rubber mounts for audi s2 ?
    All rubber but much stiffer then original. They flex but just little ,, and they dont squeek like delrin. I wonder for like group buy. If there is a interest then it would be possible. I have med for bmw e30 ,, the rear axel ,,700hk , worked fine ,, have pictures on the e30 bushing i did good quality.
    Is there a site where i can buy a complete set of bushings to hole car ,, coupe and avant ?
    Not shore what the difference is between coupe and avant.
      Verkline. Coupe has different set up at rear to Avant.
      Nothelle S2 Avant in restoration
      Wr Ur Quattro (also in restoration)
        Sorry ,, my bad .. i ment .. complete set of original bushings for s2 avant ?
          Audi will probably happily supply you.
            I couldn't find a full set when I did mine. You may be lucky and find some new old stock somewhere.
              Is there a list on all bushings for the car with oem numbers? Dont want to miss anything if i order.
              Audi s2 avant - 93
              Best Regards
                You need to use 7 Zap and look them all up.
                  I would think twice before going "back" to OEM rubber bushings for the subframes. Unless you (or your shop) are especially proficient with a press to get the new ones in. I had a shop destroy 2 bushings using a standard press. I imagine Audi had a custom rig to get the originals in undamaged. I ended up using aluminum bushings. I honestly don't know of anyone who has replaced the subframe with original 1-piece bushings.
                    Hmmmm .interesting ,,, they must have a press ,, nothing strange ,, it must be a special tool that you use between the press and the bushing.
                    I will take pictures/movie when i do it.
