Complete sets of rubber bushings
  • S2_avant 19930325
    • Mar 2019
    • 648
    Is there a demand on complete sets of all bushings and rubber mounts for audi s2 ?
    All rubber but much stiffer then original. They flex but just little ,, and they dont squeek like delrin. I wonder for like group buy. If there is a interest then it would be possible. I have med for bmw e30 ,, the rear axel ,,700hk , worked fine ,, have pictures on the e30 bushing i did good quality.
  • S2_avant 19930325
    • Mar 2019
    • 648
    Is there a site where i can buy a complete set of bushings to hole car ,, coupe and avant ?
    Not shore what the difference is between coupe and avant.
      • Dec 2017
      • 5984
      Verkline. Coupe has different set up at rear to Avant.
      • S2_avant 19930325
        • Mar 2019
        • 648
        Sorry ,, my bad .. i ment .. complete set of original bushings for s2 avant ?
        • Bowie69
          • Nov 2013
          • 2675
          Audi will probably happily supply you.
            • Dec 2017
            • 5984
            I couldn't find a full set when I did mine. You may be lucky and find some new old stock somewhere.
            • S2_avant 19930325
              • Mar 2019
              • 648
              Is there a list on all bushings for the car with oem numbers? Dont want to miss anything if i order.
              Audi s2 avant - 93
              Best Regards
                • Dec 2017
                • 5984
                You need to use 7 Zap and look them all up.
                • nribs
                  • Aug 2015
                  • 91
                  I would think twice before going "back" to OEM rubber bushings for the subframes. Unless you (or your shop) are especially proficient with a press to get the new ones in. I had a shop destroy 2 bushings using a standard press. I imagine Audi had a custom rig to get the originals in undamaged. I ended up using aluminum bushings. I honestly don't know of anyone who has replaced the subframe with original 1-piece bushings.
                  • S2_avant 19930325
                    • Mar 2019
                    • 648
                    Hmmmm .interesting ,,, they must have a press ,, nothing strange ,, it must be a special tool that you use between the press and the bushing.
                    I will take pictures/movie when i do it.
                    • S2_avant 19930325
                      • Mar 2019
                      • 648
                      Found out about what kind of tool you need. Check.
                      The bushings i cant find is 8A0505145C 4 pieces for the rear axel.
                      ( There is 8A0505145D and 8A0505145E ,, 2 pieces each in ETKA but the dont fit my car , when i check against the chassinumber )
                      Any tips ? Does anybody have used ones ? Can pay for them and shippingcost , will make new one i cant find.
                      Best Regards
                        • Dec 2017
                        • 5984
                        8A0505145C - Verkline do them.
                        I just bought the whole Verkline kit then you have everything.
                        • S2_avant 19930325
                          • Mar 2019
                          • 648
                          But i want rubber, not Polyurethane
                          • S2_avant 19930325
                            • Mar 2019
                            • 648
                            I dont like the squeeking sound in the car , but i dont know which bushings squeek ,,
                              • Dec 2017
                              • 5984
                              I don't have any squeak. You are going to struggle to find OE rubber.
