Pas tandem pump leak ,oring needed
  • Pas tandem pump leak ,oring needed
    Hi I've had the dreaded star bolt leak I've managed to get a oring and got it to seal but after removing the banjo and pipe covering the star bolt it seems to be weeping slightly from this front banjo now
    it's got 2 red rubber orings in there
    Can I just fit any oring there or are they red for a reason
    I just need 2 new to stop this very little leak.
    Ps looks like the star bolt has been leaking years
    I've marked where I need them for
    The red rubber rings are still available from Audi at £6 each
    Nothelle S2 Avant in restoration
    Wr Ur Quattro (also in restoration)
      N90405401
      If you don't live near an Audi dealer, ring Crew Audi Parts department and they will post to you.
        Originally posted by Tractor Dave View Post
        N90405401
        Thanks mate your a star , went to tps with the old ring and they couldn't find it but this number will help , cheers
          No problem.
          If you are on a tight budget you can use 11x2.5 silicon o rings. I bought the proper ones as I didn't want to do the job again. Originals lasted 25 years!
            No problem.
            Got my mate ringing up from tps Monday he says he can get them but tenner for 2
