Pas tandem pump leak ,oring needed
  • Jamesey
    • Aug 2021
    • 154
    Hi I've had the dreaded star bolt leak I've managed to get a oring and got it to seal but after removing the banjo and pipe covering the star bolt it seems to be weeping slightly from this front banjo now
    it's got 2 red rubber orings in there
    Can I just fit any oring there or are they red for a reason
    I just need 2 new to stop this very little leak.
    Ps looks like the star bolt has been leaking years
    I've marked where I need them for
    • Dec 2017
    • 5984
    The red rubber rings are still available from Audi at £6 each
      • Dec 2017
      • 5984
      N90405401
      If you don't live near an Audi dealer, ring Crew Audi Parts department and they will post to you.
      • Jamesey
        • Aug 2021
        • 154
        Originally posted by Tractor Dave
        N90405401
        Thanks mate your a star , went to tps with the old ring and they couldn't find it but this number will help , cheers
          • Dec 2017
          • 5984
          No problem.
          If you are on a tight budget you can use 11x2.5 silicon o rings. I bought the proper ones as I didn't want to do the job again. Originals lasted 25 years!
          • Jamesey
            • Aug 2021
            • 154
            No problem.
            Got my mate ringing up from tps Monday he says he can get them but tenner for 2
