new springs/shocks S2 coupé - options/availability
    I have a set of S2 coupe springs that have been professionally shortened and powder coated, I bought them off one of the lads on here but I've never fitted them. I will get them out and take some pics. I think I might have a set of stock springs as well, not sure, need to have a look, last time I was into the suspension on the car was going from KW back to the stock springs and Konis, I think I selected the best set out of my pile of springs. Definitely had some left over.
    • K Simmonds
      • Dec 2007
      • 7627
      If you've got a set of S2 Coupe springs going spare after sorting out the OP I could well be interested, not fussed about condition as long as they're serviceable... Will drop you a PM.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • Henkjan
        • 1705
        Originally posted by B5NUT
        According to ETKA the the front KV, NG, NM, A7, 3B, ABY, AAH, ABC with Air con springs are available from Tradition, unfortunately all the rear springs are obsolete. Your best option is keep searching ebay or S2 / classic Audi FB groups.
        looking for the non aircon since aircon is on ts way out
        Originally posted by steve briance
        ... if you are looking for something that cannot be bought elsewhere: Contact springcoil limited in Sheffield. ....
        thanks, I'll contact them.
        Originally posted by newsh
        I have a set of S2 coupe springs that have been professionally shortened and powder coated, I bought them off one of the lads on here but I've never fitted them. I will get them out and take some pics. I think I might have a set of stock springs as well, not sure, need to have a look, ....
        thanks. not looking for shortened springs though, but if good condition standard S2 springs appear in the pile.......
        • johne
          • Apr 2007
          • 1405
          My car has non air-con front springs. I subsequently fitted air-con but didn't change the springs. Couldn't tell the difference. I believe the rate for 895 411 105A (front springs with air-con) is 210llbs/inch. Don't know the rate for non air-con front springs.
          I did a recent refresh of my shocks, kept the original springs (orange, orange, blue, white front; orange, silver, silver rear) and used Bilsteins 34-030868 on the front and KYB 366008 on the rear.
          • Henkjan
            • 1705
            I finally managed to source some springs, and bought the yellow Koni shocks. will be mounted soon....
            • anthonys2
              • 3512
              Can I ask where from as I need to start looking soon for some new Konis and I might as well sort the springs out at the same time
              • Henkjan
                • 1705
                https://www.kleinanzeigen.de/s-anzei...76198-223-7230
                • Henkjan
                  • 1705
                  after some delay, the car is finally up in the air...
                  so immediately the usual issues: the cap (#25) will not come loose, and the cover (26) and bump stop (27) seem to be NLA. But al least it seams autodoc do have an alternative for those: https://www.autodoc.co.uk/monroe/743...shock-absorber
                  • johne
                    • Apr 2007
                    • 1405
                    Cut through the side of the cap at 45 degrees with a hacksaw until almost through above the threads. Use a cold chisel to part the cap and drive it off.
                      • Dec 2017
                      • 5983
                      The aftermarket versions sold by Autodoc are not a good fit. Last time i looked, Tradition were still selling original covers. Bump stops more difficult to find.
                      • Henkjan
                        • 1705
                        yep, same experience here (on all points)
                        car has low prio now, both from me and at the garage where it is has been occupying a bridge since july....
                        • The Spanish
                          • Nov 2003
                          • 719
                          #42
                          This guy seems to have some rear springs
                          https://www.ebay.de/itm/305132241034...40dDDFyY4JCLdI
                          94' RS2 Coupe TT (Twin Torsen )
