Anybody knows ? (ACOQ diff mounts)
  • pfi
    • Jun 2016
    • 274
    • Country: Norway
    Needs a pair of new diff mounts/bushings (857599431) for my ACOQ
    hard to get locally and expensive on the net ...
    Anyone know if eng-mounts from A100 C3 (443199381) has same dimensions ?
  • quattrodave
    • Dec 2008
    • 218
    Pretty sure febi do a compatable mount for about £10 to £15 in the UK so you should be able to source one in your country
    • pfi
      • Jun 2016
      • 274
      • Country: Norway
      £10-15 is a fair price, probably searched wrong sites, found it from ~£50 ...
      Febi part # ?
      • quattrodave
        • Dec 2008
        • 218
        I think the febi part is of the equivalent replacement audi part number 431399151d which is a gearbox mount, from memory when I last changed these the front and rear bushes were the same dimensions so unless its that important due to some difference in the rubber stiffness I would go with the gearbox mount on the rear diff, worked for me on 2 x audi 90's a 10v and a 20v.
        There are lots of other pattern copies of the audi 431399151d available from around £8 upwards in UK so you takes your choice and pays your money for your prefered make.
        • quattrodave
          • Dec 2008
          • 218
          have a look here been discussed previously - https://www.s2forum.com/forum/techni...unts-different
          • pfi
            • Jun 2016
            • 274
            • Country: Norway
            Thnx alot !!!
            431399151d is available at my local dealer for a reasonable price
            • Lago Blue
              • Jul 2009
              • 843
              pfi ,
              Despite its title, if you haven't seen this already, where this thread went to may be of interest:
              • pfi
                • Jun 2016
                • 274
                • Country: Norway
                Originally posted by Lago Blue
                pfi ,
                https://www.s2forum.com/forum/member...ket-for-b3-use
                Thnx !
                Not seen that post, marked as interesting
                Ordered 431399151D from my local dealer
