91 Coupe Quattro with S2 Coilovers?
  • Mean_Crstne
    • Jan 2024
    • 4
    Very new to the platform, I read an older post describing the compatibility of the suspensions in the different models, from what I understand, the S2 would have the same suspension layout as a US coupe Quattro (1991).
    I just wanted an expert or someone more familiar than I to chime in and confirm this. BC racing has coilovers that fit a 1990-1995 S2 and wanted to make sure for future reference they’re compatible.
    Thanks!
  • K Simmonds
    • Dec 2007
    • 7627
    Welcome to the forum.
    Yes the suspension layout is the the same aside from one slight difference, the front wheel bearing carrier's on your US 7A engine CQ will have two holes in the front bearing carrier for 12mm strut mounting bolts.
    Apart from a few very early car's all S2 Coupe's use 14mm bolts in this location and the BC coilover's will be designed to use the larger diameter bolt.
    However, your front hubs's can have the two front strut mount bolt holes drilled out to accept the larger diameter bolt, I did this very modification to my early S2 in order upgrade to the later design.
    It is however vital that these hole's are drilled perfectly straight, I wouldn't try doing it by hand. I gave my bearing carriers as well as one of the later type bolts as a sample to my local machine shop who did it for £20. The hole's need to be 14.5mm or just under to allow the bolts to fit.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • Mean_Crstne
      • Jan 2024
      • 4
      Thanks so much for the warm welcome and incredible information, that’s exactly what I was looking for! Best of luck with your projects as well.
      • varia
        • 821
        • Current: United States
        you can order it from Kirk, if you are in the usa:
        KW V3 Coilovers for B3 Audi quattro vehicles (80, 90, Coupe Quattro, S2 Coupe) Note: 3-12 week standard lead time, ships from Germany $95 shipping charge is included in the product price Unlimited individuality for performance & comfort. Damping forces can be adjustment separately in
        • ottawa coupe
          • 852
          I've got the bc racing kit on order. I'm roughly 4 weeks in, my guess is another 4 till i get them. I have been told that they come with shims to account for the 12mm vs 14mm holes.
          If you're really worried about that, find someone parting a b4 cabrio, my 94 parts car has 14mm uprights.
          1993 UrS4...aka the rocket powered living room
          • Mean_Crstne
            • Jan 2024
            • 4
            Thank you all for such fantastic info. Ottawa when your BC coilovers come in, would you please post back or do a separate right up on their fit, finish, and performance? I would love someone’s intel with hands-on the kit.
            The BC customer/sales support had very little info on the kit and little to no reviews. Thank yall!
            • ottawa coupe
              • 852
              Well, i'll certainly give you an update when i get them, but you'll see from my project thread, i am a FEW weeks from driving on them lol....
              • jbrentd
                • Dec 2009
                • 247
                My BC coilovers showed up last week and they do have hardware to work with the 12mm bolts. You can see them in the top right of this picture. They also come with sway bar links. These will be going on my US '91 CQ soon.
                2001 A4 Avant QMS - FXK04'd
                1991 Audi CQ - Project
                1996 A4 12v Quattro Manual - SOLD
                • Mean_Crstne
                  • Jan 2024
                  • 4
                  This is exactly what I was hoping for. Thanks so much and if you install them do tell of your experience. Thank you!
                  • jbrentd
                    • Dec 2009
                    • 247
                    You bet. In case I forget to come back to this thread, I will be posting updates in my build thread as well.
