Wheel bearing
  • nbswbdl
    • Nov 2024
    • 6
    Wheel bearing
    Hi all.
    On S2 wheel bearings, what retains the bearing in the casting? I would normally expect a circlip to retain it, but there's no groove and no circlip! Any help greatly appreciated!
    N.
  • rxl
    • 1913
    you will not find anything
      Originally posted by nbswbdl
      Hi all.
      N.
      It's pressed in.
        • Dec 2017
        • 5983
        Don't forget to support the inner race when pressing in the hub
        • nbswbdl
          • Nov 2024
          • 6
          Originally posted by newsh
          It's pressed in.
          So it's just pressed in, and there is no way it is retained in the upright? So long as I haven't missed something, then I'll run with it!
          • Antsa
            • Nov 2016
            • 611
            Nope, no circlips no nothing. The bearing is just pressed in. Also, remember to install the bearing the right way round. The inner race of the bearing is stepped, the larger diameter must face outwards.
            • Davi123
              • Feb 2016
              • 98
              Anyone know the torque setting for rear hub nut please? Replaced my bearings and i found the front setting 200nm plus 90 but as bolts on rear are smaller I wanted to check the rear torque setting. Thanks
              • Nuvo
                • Nov 2003
                • 3825
                The M14x1.5 bolts are 120Nm + 90°.
                • Davi123
                  • Feb 2016
                  • 98
                  Thanks Nuvo.
                  • monaca
                    • May 2026
                    • 1
                    • Home: Scotland Current: Wales
                    On many S2 hubs the wheel bearing is actually retained by an interference press fit rather than a circlip, so it can look odd if you’re expecting a visible retaining groove. The hub casting is machined so the outer race is a tight fit, and once the driveshaft/stub axle and retaining nut are torqued up the assembly effectively clamps everything together. The important thing with these bearings is making sure the housing hasn’t worn or spun, because if the fit becomes loose the TBS bearing can start moving in the casting and damage it fairly quickly.
