S2 Coupe suspension options
  • HPmuirt
    S2Forum April Fool
    • Apr 2005
    • 3014
    Greetings folks,
    There are thousands of threads on the forum regarding the many suspension options, but I would like some opinions on what works well, so that we can come to an agreed set of options.
    For my car, I would like to maintain most of the softness of the OEM ride and also the OEM ride height, as Cambridgeshire is infested with speed bumps. I have just replaced the wishbone bushes with OEM items and will fit Pro mounts to the front and mount savers to the rear (from Corey) which raises the car about 5mm.
    So, what combination of springs and dampers will give me the most cornering performance, for the least harshness of ride? Also, what is the difference between S2 and RS2 front set ups?
    Secondly, can someone list the best combinations in order, from OEM/soft through to race/hard?
    Cheers n
    Si
    Subtle mods here and there
    2011 A5 3.0 TDi - Lava Grey
    Soft too Hard - I've had nearly all of these combinations on my old S2 coupe.
    OEM Springs & Shocks
    OEM Springs & Koni Shocks
    Koni Springs & Koni Shocks
    OEM Springs & RS2 Shocks ( Coupe RS2 front Only )
    H&R Spings & Koni Shocks
    OEM Springs & Bilstein Shocks
    H&R Springs & Bilstein Shocks
    For you the best option would be Koni shocks & OEM springs by a miles.
    Bilstein & OEM is another good combo but hard on rough roads.
    • HPmuirt
      S2Forum April Fool
      • Apr 2005
      • 3014
      Thanks for that Jamo, just what I was looking for. Any idea how they compare, i.e. could you rate them so that we can see how similar or different each step is?
      I didn't realise that the RS2 front shocks were so much harder than the S2 ones? For those who use RS2 fronts, what do they use on the rear?
      It is certainly sounding from what I have read and what you say above that the Koni/OEM setup is what I should go for. Is it ths springs or dampers that have to be rated for the additional weight of the air con?
      Cheers n
      Si
      • Fat Audi 80
        • 10547
        I would not say OEM springs and Billy's are at all hard. Perfect on bumpy A -roads, everso slightly soft on fast flat smooth roads and possibly the track. IMHO
        Cheers,
        Steve.
        The Perfectionist
        • Jas11n
          • 5067
          OEM springs/Koni shocks for me. Everything else OEM (non of this """"uprated"""" balls---flame suit on :mischeif: )
          Love it..
          Jas..
          2001 Avus Silver B5 RS4.
          1995 S2 Coupe - sold (sniff)
          • s2driveruk
            • 12696
            can confirm on anything other than a decent surface the billies and H&Rs can be a bit harsh, definately not great on a b road.....i think with an rs2 front anti roll bar it would be a good 'fast road' setup. I love the ride except when i am tired and all it does if fidget then i wish i was in the a6 'armchair'
            1992 3b S2 Coupe
              [QUOTE=Jas11n;222341]OEM springs/Koni shocks for me. Everything else OEM (non of this """"uprated"""" balls---flame suit on :mischeif: )
              [QUOTE]
              LOL
              Ive got koni's H&R and poly bushes and ride is harsh on B roads alot better on the track though and flatter roads.
              • CoupeWannabeS2
                • 403
                Just noticed this thread and wondered where to go to buy the Koni Shocks ???
                One of my rear shocks has leaked all of its oil so the option of standard springs and Koni shocks looks like a good idea.
                • Rusty
                  • 18953
                  Standard springs, koni shocks and uprated arbs. Good control and ride quality with standard ride height. Stiffer springs would be nice but spped humps + lowered S2 =
                  • s2driveruk
                    • 12696
                    Andy I have less problems getting the S2 over speed bumps than the a6 bus we have...it usually drags the engine belly pan or just catches the nose while the s2 sails over them
                    1992 3b S2 Coupe
                      Cheers,
                      Steve.
                      That is true on anything smooth, but on a bit rough they are not very forgiving.
                        Cheers n
                        Si
                        Search you lazy sod
                        It's the springs that are rated for air-con. They air-con springs sit higher than non-higher aircon but do help a bit to stop nose diving on braking.
                        • HPmuirt
                          S2Forum April Fool
                          • Apr 2005
                          • 3014
                          OKie, so the next question is....
                          Were is the best/cheapest place to sourse Koni shocks and OEM springs?
                          Cheers n
                          Si
                          P.S. @ Jamo what is the point of searching when you know everything
                            Get you Koni shocks from Aelred you wont find a better deal.
                            Doubt you'd need new OEM springs unless yours are fubarred. But if so P.Diddy or Vagparts
                            • Fat Audi 80
                              • 10547
                              Not in my car.
                              I like them anyway, but have never tried anything else....
                              The Perfectionist
