I went for RS2 shockers, as alg said still handle well, but also has a bit of comfort!
it's about personal choice too!
I would also say you can't go wrong with the H&R's!!!
For off the car adjustable Konis, there should be an allen key hole in the top of the piston rod.
Push the rod all the down, insert allen key and turn, you should feel a positive engagement.
Turn one way to the softest setting, stop when you feel the pressure change and do not force it to turn any more! this can be confirmed by pulling the rod out by hand. If you can do this this is the start point.
Rotate to the next stop, counting how many turns it is.
You can now set a percentage turns for the damper and keep a note of it!
Does for me on my 90.
Carlos.
