Koni shocks don't fit....PLEASE HELP!!!
  • GT500
    • Jun 2006
    • 2181
    Now you know why I have a lathe in my workshop!
    10 minutes later perfect spacer!
    Sorry can't help! other than get some Bilstiens!
    Rob..
    87 UR 20v ABY
    97 S6 Avant
    • Acidburn
      • 13459
      From what it sounds like I will be picking up a pair of these shocks for on the front of mine in about ten minutes so will try them in the housing before I drive them down to where the car is and let you know later today.
      • pixsaudisex2
        • Sep 2004
        • 3110
        plastic washer in mine when i got them... but i will say one thing for konis they a pretty cr@@p for instructions thats for sure.
        • AndyP
          • 6049
          Mine is a 91 3B with chassis code M.
          Now you come to mention it there was some white plastic washers with the dampers, but there was no mention in the instructions of them so I din't use them.
          Andy
          • Acidburn
            • 13459
            Right picked mine up earlier and thank god 4th time lucky they was the right ones.
            Got the 2x shocks, 2x metal rings for the top of the dampers in between them and the caps for the leg, new nuts and 2x plastic rings for the adjustment. Sounds like you might be missing the metal rings that space between the damper and cap
            Will try get some pictures of the whole kit before I go home as at present still in hertfordshire.
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #21
              I've got an oddball M chassis and don't recall having any spacers, if that helps?
              SS
                Originally posted by S2central.net
                Simon - A 1992 3B should be same strut as all ABY struts according to FA.
                Its the 1991 3B (M) which is the oddball. The comments about 7A and UR with Konis just add to the confusion as they are different struts again.
                They aint the same BTDT the thread size for the bolts are different M12 vs M14
                • volcano rs
                  • Jun 2005
                  • 2265
                  deffinetly spacers rings .i had to fit them in mine and i've had no problems it could be that the spacer you have is not tall enough i had some machined out of stainless .
                  • AndyP
                    • 6049
                    You like your stainless don't you
                    • volcano rs
                      • Jun 2005
                      • 2265
                      you know that
                      • HPmuirt
                        S2Forum April Fool
                        • Apr 2005
                        • 3014
                        #26
                        Final update:
                        As I said earlier, I DID have the spacers fitted, but even so, my Konis were too short.
                        The spacer is not a flat washer-like disc, but it cups the end of the damper and holds it in the centre of the strut tube. The spacer is supposed to sit 1 or 2 mm higher than the top of the tube, so that the top cap clamps down on it.
                        My spacer sits below the top of the strut tube by around 1.5mm, making the Koni around 3mm too short
                        The cr@p Koni instructions suggest taking a hacksaw to the top of the strut tube to remove between 3 to 6mm, thus making the spacer proud, but that means removing the start of the threaded portion which I REALLY don't like.
                        The white plastic washer is supposed to go around the piston of the damper, under the rubber boot and seems to be a scrapper or protector of the damper seal. I would suggest that it should NOT be fitted in compression to hold the damper in place as it is thermo plastic and therefore has little compressive strength.
                        The car is now back together and drives very well, however I know that there is a bodge washer in each strut tube and I REALLY don't like that.
                        At the same time I also fitted Pro mounts at the front and mount savers at the rear so I will post a seperate thread on how the car feels with this set up, when I have covered a few miles.
                        Cheers n
                        Si
                        Subtle mods here and there
                        2011 A5 3.0 TDi - Lava Grey
                        • AndyP
                          • 6049
                          You wouldn't have to bodge it if you bought the superior 3B model
                          • HPmuirt
                            S2Forum April Fool
                            • Apr 2005
                            • 3014
                            #28
                            All that dizzy whine, lack of overboost, missing 5th gear, awful airbox and undersized wheels (for 996 upgrades) put me off
                            Cheers n
                            Si
                            • Acidburn
                              • 13459
                              Lmao, still had a 3b beat yours in the recent RR day
                              - must have been the de-cat pipes as I don't need them.
                              • mcandmar
                                • Apr 2004
                                • 5118
                                Exactly what it is, to prevent the bump stops from damaging the shock seals.
                                91CQ20v - Gone to a new home
                                93UR-S4 - The Magic Carpet
                                94S2Bus - The Emerald Express
