Subframe bush removal
  • Nasty90
    • Jul 2007
    • 6
    When I installed my A-arm bushings I used a ball joint press tool I got as a loaner. The way I used it, I placed the large C-clamp on a table vise and placed the A-arm on and set the new bushing on top for pressing. If you got air tools, fire on it. It's labor intensive, but it will get the job done.
    • QuattroFever
      • May 2006
      • 1360
      Sorry if this sounds stupid but i'm doing this job next week at home. Under the car!!
      How do you get the new OEM rubber bushings in??
      Big F*****G Hammer??
      or should they just pop right in
      Volcano ABY coupe
      Ant
      • baltiboyS2
        • 965
        Need to press them in or you can buy one of these it will take five minutes to do
        http://cgi.ebay.co.uk/Ford-Cortina-R...QQcmdZViewItem
        cheers Raj
        • QuattroFever
          • May 2006
          • 1360
          Are they like a standard size or is it just coincidence that cortina rear axle bushes are the same? if they are then i can get a tool on a buy it now?
          Volcano ABY coupe
          Ant
          • s2driveruk
            • 12696
            i just got a local garage to press them out for me, cost a little more than i wanted to pay but no a**e ache doing it myself
            1992 3b S2 Coupe
            • QuattroFever
              • May 2006
              • 1360
              aaargh, i'm dreading it but just skint at the mo and got a track day on the 12th april
              anyone wanna do it for me and I'll be your slave for a week!!!
              Volcano ABY coupe
              Ant
              • baltiboyS2
                • 965
                I borrowed the exact item from one of my fellow colleagues and it works a treat i am going to buy full kit for doing various cars and its a hell of lot cheaper than on ebay
                http://cgi.ebay.co.uk/Sealey-VS4465-...QQcmdZViewItem
                Cheers Raj
                • Knight Rider S4
                  • 3541
                  cheers Raj
                  This is on my watch list now
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • QuattroFever
                    • May 2006
                    • 1360
                    mine too :mischeif:
                    Volcano ABY coupe
                    Ant
                    • baltiboyS2
                      • 965
                      There is buy now ones below
                      http://cgi.ebay.co.uk/FORD-CORTINA-V...QQcmdZViewItem
                      http://cgi.ebay.co.uk/Ford-Cortina-M...QQcmdZViewItem
                      The very first one listed does both the larger and smaller void bushes on the cortina but these others just do small or large
                      but the cortina one is the one to go for i will check the vauxhall ones on monday as i have a subframe bush handy and will check as that opens up more tools to go for
                      cheers Raj
                      • QuattroFever
                        • May 2006
                        • 1360
                        cheers Raj
                        Got one sorted now.
                        Volcano ABY coupe
                        Ant
                          Raj is it best to go for the small or large Cortina one if buying individually?
                          I've got both subframes to rebush, as well as my wishbones if i can adapt the tool to work, one of these tools will make my life a lot easier!!!
                          • Tonks4x4
                            • Nov 2005
                            • 3062
                            Bushes
                            Universal Bush Remover
                            Audi Nut!!!
                              nice!
                              • urquattro-island
                                • Mar 2006
                                • 1915
                                • Home: Norway Current: Iceland
                                #30
                                yup
                                like i said burn baby, burn
                                japanischer industriabfall nein danke!!
                                www.rackeltrim.se Icelandic Division
