Subframe bush removal
  • terrybullwon
    • Mar 2006
    • 8782
    Guys any tips?
    I have read there is a special tool for this Job in a old thread, i was just wondering if there are any other ways to do this other than hack sawing out the rubber bushings?
    Cheers James
    Chef
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    let it
    burn baby burn...
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
    • AndyP
      • 6049
      I did mine last week, I used a piece of steel tube and a length of threaded bar to make a sort of puller to rip the rubber inner part out and then used a small chisel to remove the outer steel ring. It was hard work though!!
      • topsparky
        • Oct 2005
        • 2014
        you should have put some weight behind the hammer then
        i could have lent you some
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        6. UPRATED HIGH OUTPUT COIL PACK
        7. ,3" turbo back s/s/ exhaust
        8. fmic fitted
        • terrybullwon
          • Mar 2006
          • 8782
          Bloody hell, well i got two out but the rest can wait till i put them on a press
          Chef
          • AndyP
            • 6049
            Thats what I thought after the first one, but I'm stubborn
            • volcano rs
              • Jun 2005
              • 2265
              you would have crushed it
              • faaaaast
                • 124
                Having pressed some bushes in/out in the workshop, I fully respect anyone who does this at home
                Bring the other two into Barry's if the subframe's off the car... have them out in a jiffy...
                '91 S2 Coupe
                '92 A80Q 2.8 V6
                '92 A80 2.8 V6
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Thats the Plan
                  Its just i had to have it ready to be blasted tomoro, so i cut the bushes down for time being
                  Chef
                  • s2driveruk
                    • 12696
                    good to see someone else grafting away and that is a bithc of a job to do....are you going down the alloy bush route for replacements?
                    1992 3b S2 Coupe
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Yeah i all ready have them
                      Will be interesting to see how well they work
                      Chef
                      • faaaaast
                        • 124
                        They will work very well for removing old fillings before you next go to the dentist
                        Well, we are talking about Island roads, here!
                        Good God, what time is that ferry leaving in the morning?!
                        James
                        '91 S2 Coupe
                        '92 A80Q 2.8 V6
                        '92 A80 2.8 V6
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          James
                          Dont remind me, sounds like they will be just fine then :mischeif:
                          Chef
                            I wouldn't be bovvered with all that elbow grease unless it was the only option - these are MUCH easier to remove and install on a press.
                            • brinskan
                              • Oct 2004
                              • 52
                              My friends have a press at their shop, but since they didn't have all the right fitments, I just burned mine out. I heated up the bushing with a propane torch, trying to not heat the subframe. Once it was hot, they basically popped out with a pry bar. Just take the prybar and get it under the flange and work it around. It took me 15 mins to do all four bushings.
