Wishbones & Wishbone bushes
    What is the advantage of running the cast wishbones over the pressed steel type?
    My fwd coupe is suffering knocking due to worn front w/b bushes. It has the pressed steel type w/bs.
    I've got a pair of cast front wishbones with decent bushes in, and also have decent bushes in the pressed steel wishbones on my CQ project car. I plan to poly bush the CQ soonish, but wondered if it was perhaps better to take the good wishbones off the CQ to replace the duds on my fwd coupe, then poly bush the cast arms I have knocking about and bang them on the CQ?
    What are peoples thoughts on this?
    I'm under the impression the Superflex bushes are the ones to go for - but that the pressed and cast wishbones require different bushes?
    Can anyone help me with the right superflex part number for the cast and the pressed type arm bushes?
    Alex
  • mcandmar
    • Apr 2004
    • 5118
    I changed mine over to the cast versions, cant say i noticed any real difference. The pressed versions will flex more, and i have heard of them cracking in places.
    The cast arms also have larger bushings, currently running the Powerflex bushings and its nice and tight. Some people complain about noise and issues with them squeaking when they run dry but i havent had any issues yet.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    • LHD_Kid
      • May 2006
      • 3695
      As far as I know, Superflex don't do bushes for the cast type, only for the pressed, whereas Powerflex can supply both sizes..... (although I may be wrong...... )
      Chris
      • Acidburn
        • 13459
        powerflex have changed the designs to stop the squeeking. I'm gonna get some soon from vagparts as they sell them iirc around ÂŁ40 ish quid, its on the website tho.
          ÂŁ40 a set of 4?? thats cheap mate
          The Superflex were looking at just over ÂŁ80 for the 4.
          So the verdict on Powerflex is that they are much improved now?
          • s2driveruk
            • 12696
            personally found with everything refreshed on mine and changing to the forged arms that there is more direct steering and feel. Could be a total placebo but to me at least it feels more 'together' than before
            1992 3b S2 Coupe
              i'm just wondering if there is any point in going to the trouble of keeping the forged arms really, its for my CQ, so never going to come under enough stress to break them (i hope!) but i can't wait to poly bush it, its made a HUGE difference in every car i've dnoe it to
              • Acidburn
                • 13459
                I personally would go forged out the two, just looking at the quality of them compared to the pressed, plus if your going to "bush" a pair i'd just do that, bigger bushes for same price would offer slightly better dampning i'd have thought.
                  hmmmm..... don't know what to do!!!!!!!!! ARghh!!!!!
                  • Acidburn
                    • 13459
                    Just fit the forged as tbh I found them better on my car, s2's are fitted with them (afaik) and they look like they will last a lot longer than pressed and are getting harder to get hold of.
                      i think it will boil down to how hard it is to get the arms off the cars really
                      from memory they are an ***** to do with where the bolt is "inside" the subframe
                      • Acidburn
                        • 13459
                        Lmao, very very easy to remove, just use a (iirc 17mm or 19mm) drop head spanner on the bolt inside the subframe and same on outside then it just drops out literally.
                        • mcandmar
                          • Apr 2004
                          • 5118
                          Go for the cast. AFAIK they only fitted them to late model S2 and RS2's so they must be better
                          • Acidburn
                            • 13459
                            Hmmm I thought it was early s2's and they changed to pressed on the late one to cut down cost? All 3b's i've been under (can't remember about david's) had them and so did my 20v quattro sport.
                            Still never know with audi and there mix and match, parts bin special cars.
                            • s2driveruk
                              • 12696
                              My late 3B (Aug 1992) was with pressed version all round
                              1992 3b S2 Coupe
