Started into some long awaited tasks tonite and am amazed to report the miraculous removal without damage, bloodshed or large percussive instruments of the following items which have always given me jip on other cars... This stuff is ~14yr old and never been off before. In preparation for new front wheel bearings.
1 - The silly lil bolts and front disc splash shield - WD40 some patience and a nice tight 10mm socket with a bar just the right size
2 - Front ABS sensor - lots of WD40 again, tick tock and *gently* levered it out with a 2-pin fork. Did tap the housing 1st of all to loosen with a hammer & drift though.
3 - Bottom balljoint on front wishbone. This surprise me the most... Loosened the wishbone bolts at the subframe to release tension. Removed the bottom joint nut and bolt and with a larger 2-pin fork was able to lever it out gently without damaging the rubber. Also tapped that housing with the drift to persuade the thing out. Turns out the joint is well tired so thats more parts for Santa to bring. If it had been a healthy part I would have ripped the rubber of course.
Well impressed though.
Paul
Paul
but this sight has cheered me up no end
