are the stock front and rear stock spring rates the same then
seems odd give the weight balance ont hese cars, although the rear beging stiffer would help with the understeer tendancies... interesting Andy. Is that what you run with?
Try 29909-VA for Avant fronts and see if they're cheaper, should be the close to 29939-VA.
If you want ultra-stiff springs then RS2 H&R fronts are 29969-VA. :mischeif: These on the back would reduce understeer but not got details on spring rates so could be a step too far, especially with a heavily uprated RARB
Are there any problems fitting the front Avant springs on a Coupe?
Is it the same only that the Avant is less stiff or what?
One would think that the Avant and Coupe would have the same springs up front as they probably carry similar weight.
And if I go for front Avant springs front+rear on my coupe, will the rear on the Coupe look like a flag pole or something, poking up a mile high?
This will surely be a cheaper option since I got £400 delivered from ShyAuto and €333 from reinekeshop.de and about €400 locally here in Sweden.
