Who does poly bushes and ball joints for the UrS6?
I can't find anyone that lists poly bushes for the UrS6. Does anyone know where I can get them from?
Also, does anyone know what bushes there are on the UrS6?
PLUS ball joints
UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Most common ones to fail are on the front, if my memory is correct they are the ones that go through a wishbone where the anti roll bar bolts through, top mounts i suppose as well, mind you i chnaged my top mounts when i had an s6 couldn't find anything wrong with the ones i took off.
Rear end is quite complex again i did some bushes but frankly i think i wasted my money and time doing it. biggest improvement was shocks the fronts go off quite quickly i ended going for oem spec bilstein, previous to that i had koni's on an urs4 and found them too hard.
btw front shocks are easy to do if you have the audi tool no more than 20 mins per side.
If it's the same as the UrS4 then the ball joint is built into the track control arm, these are available from ECP for about £100 each for Lemforder or £32ea for Ching chong chinese specials.
