Did all 3b/ABY S2 coupes have the same rear suspension?
  • PeterS
    • 425
    save for the fact that the wheel housings and uprate mounts changed from 12mm to 14mm bolts/nuts with the change from the 3B to ABY engine?
    I am under the (probably) incorrect impression that the ABY had the B4 rear suspension...
    thanks!
    -Peter
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
  • Mikes2
    • 1704
    thanks!
    -Peter
    There never was a B4 Coupe. rear suspension of the Coupe never changed except for the ARB being added in 1990 which never applied to the S2 anyway.
    Mike
    http://www.s2-audi.co.uk
      All S2 uprights / knuckles use 14mm bolts don't they?
      • Flat on my back
        • Jan 2007
        • 2449
        You'll only find b4 rear sus. on a b4 80 sedan or avant or RS2...like to one i'm converting.
        Carlos.
          No £B is 12mm ABY 14mm
          They are exactly the same bar this.
          I've fitted 3B rear and front struts to an ABY before.
          • geryS2
            • May 2006
            • 814
            • Home: Belgium Current: Portugal
            rear triangle suspension is not the same, but i don't know what s the difference,
            i had to order a new one and it s not the same for 3B or ABY.
            S2 's and oldtimers
              Forgot that bit I swapped them over from the ABY parts.
