Just finished fitting my S2 coupe H&R spring kit to my converted CQ ABY.
I just used the existing Koni adjustable shocks that were only fitted 2 years ago.
The fronts fit fine, but it appears that the rear Shocks are too long. On full extension of the shock. The spring dislocates.
From what i can tell, when i removed the CQ lowering springs (came with the koni kit) they were doing the same, as the spring was no longer seated properly.
Not really happy with this, as any airtime/shock full extension on the 'ring could dislocate my spring
Is this normal with the H&R Spring - Koni Damper setup? Do i need Koni S2 rear shocks? Does anybody have any knocking around?
The stance and ride are awesome BTW!!
considerin usin h&r too but my set up is oem.me thinks problem is your on oem cq shox now you fitted shorter s2 springs an oem s2 springs might already be shorter than standard cq............
if you no what i mean.best of luck fella
