anything else then this i need?
034motorsport 19mm rarb
034motorsport jhm solid short shifter
034motorsport strut mount " track density"
034motorsport engine/transmission mounts "motorsport spec"
034 motorsport Mount, Diff Carrier Pair, B4/B5 "track density"
034motorsport rear diff mount poly
034 motorsport diff/ tranny mounts "track density"
k&w coilovers
toyo tr-1 tires
drilled discs
better pads, (suggestions?)
better brake fluid
delrin bushings overall
k&w coilovers
toyo tr-1 tires
drilled discs
better brake fluid
) or what they are called provide MUCH more grip when you have all the other above upgrades. Be prepard to drive fast with them!
I am waiting for someone to post their experiences of the clubsport kit!!..
