Powerflex rear diff mount bush
  • dan_b
    • Sep 2003
    • 3670
    Well, after 7 weeks, my Powerflex rear diff mount bush finally arrived this morning. Going to install this over the weekend (using the BTDT in the guide section of this excellent forum) and see how I get on. Have been noticing a wee bit of transmission thump, plus a bit of off-throttle herky-jerkiness, so hopefully this will help a little.
    Good quality looking piece of kit, hopefully worth the wait...
  • s2driveruk
    • 12696
    Dan where did you get it from, this is my next job after the wishbones and a front end camber/castor and toe alignment tomorrow.
    Cheers,
    David
    1992 3b S2 Coupe
    • sal_s2
      • 1288
      You can order one from any Ripspeed Halfords, think they charge around 29 quid all in
      • dan_b
        • Sep 2003
        • 3670
        I went to the Powerflex website www.powerflex.co.uk and then ordered it from the distributor who was nearest me, in my case this was "Croydon Race and Rally"
        Cost me a shade over 30 quid what with delivery and VAT and all.
        • s2driveruk
          • 12696
          Cheers Dan....... Let me know how you get on fitting it
          1992 3b S2 Coupe
          • dan_b
            • Sep 2003
            • 3670
            Will do - there's a very good BTDT guide on this forum, will be following that...
            • s2driveruk
              • 12696
              will be interested to know if it does cure that lift of thud you get, mines quite bad, got visions of the diff and prop wandering all over the shop underneath the car
              David
              1992 3b S2 Coupe
              • dan_b
                • Sep 2003
                • 3670
                Exactly what I'm hoping to cure! Will update when fitted.
                I've just looked at your car website by the way - nice piccies. Have you done the servotronic disconnect mod? You mentioned a lack of steering feel, which plagues all 3B S2s, but its easily cured, a 2 minute job which is free!
                • s2driveruk
                  • 12696
                  hmm, need to disconnect it!!!! keep forgetting that mod. As for the site, needs bloody good update but never seem to have the time.
                  How heavy is the steering at low speeds and does it add any extra work for the p/s pump with it disconnected?
                  1992 3b S2 Coupe
                  • Rob W
                    • 353
                    Cheers for that info i was wandering,where to get these as my local stockist,didnt stock it,and seemed reluctant to order it.
                    Rob W
                    04 Audi S4 Avant
                    55 Merc 220cdi c class estate Family hack.
                    92 Audi S2 3b Sadly gone.
                    1969 mustang fastback 302. Dry storage
