Sway bars for the s2 avant
  • Big Lee M
    • 2571
    I wouldn't have thought so? But i haven't seen a coupe rarb? Have you got a pic of the brackets for the coupe rarb?
    Just some finishing touches to do now
    • stiglet
      • Aug 2007
      • 1264
      Now that i think about it it's probably because my whitline bar came with poly bushes which probably wouldn't fit in the standard mounts. Suprised the Avant bar doesn't come with any of these things.
      Mine is adjustable but not sure how that would affect the mounts?
        Originally posted by MidnightBlueS2
        My understanding is that the Avant RARB stock brackets are suitable for much stiffer ARB's but the subframe flexes a bit which is not "really" desirable though not a real problem. Neuspeed supplies brackets to prevent the flexing of the subframe.
        The coupe Whiteline RARB supplies brackets as it's an adjustable set-up with 3 different RARB positions of stiffness.
        The subframe doesn't flex, it cracks which is why Neuspeed used the brackets
        Originally posted by s2avant
        It's clear why this is needed when you look at the standard ARB mounting points. They are literally flat plates that protrude from the bottom of the subframe. After much investigation on the web it seems common that on A4Q/S4s these can crack or even snap off when bigger rear ARB's are used.
        • Bram
          • Aug 2006
          • 2582
          Will these B5 H&R anti-roll bars fit? Front and rear anti roll bar kit. Diameters (front/rear)= 32/21mm
          • MidnightBlueS2
            • Jul 2005
            • 1653
            • Home: United States Current: Belgium
            #20
            http://www.s2forum.com/forum/showpos...15&postcount=1
            Thanx for the link Jason. Interesting read and great pics. But I'm fairly sure that if Audi intended the brackets to work with an RS2 RARB which is fairly quite identical to a Whiteline RARB, there shouldn't be any cracking/snapping like in the S4/A4q's.
            Maybe the S4/A4q's brackets are made of aluminum or some other alloy instead of iron ?
            Midnight Blue S2 - SOLD - 1993 S2 Avant
            • Big Lee M
              • 2571
              Well I just spoke to someone at Awesome GTI about the brackets for the neuspeed rarb and it's called the fitting and it's about £60-£75. So I think I'll stick without it.
